About Subafly
- Birthday 11/09/1985
Contact Methods
AIM
extreme boarder0
Website URL
http://
Location
Cheney, WA
Interests
wheeling and board sports, music, girls : )
Occupation
Student at Eastern Washington University
Ezboard Name
subafly
Biography
I like to be in the air, like snowboarding, bmx, I pole vault. Im also a spead freak. I like to downhill skateboard/streetluge(one I made from wood), snowboarding, mounatinboard. Ok Im an adrenaline junkie. I am a music major at EWU
Vehicles
84 gl Daily D, 85 gl LIFT
Subafly's Achievements
USMB is life! (4/11)
10
(And subafly)
mystery ring inside transmission!?!?!?
Subafly replied to Subafly's topic in Old Gen.: 80's GL/DL/XT/Loyales...
there we go. -
totally the wet side although its not bad today. clutch went out on the way over, managed to get it to the parents to use their garage though! ya its kinda a crazy little piece, could have just fallen in through the access hole which has never been covered since Ive had the car. Kinda looks like the outer race of a bearing. its got a groove down the middle. thanks B. Ill hit ya up sometime this summer. My baby needs to grow a few inches:grin: -
Im doin the clutch in my 84 Gl wagon and In the procecess of cleaning the bell housing I found a small round ring broken into four pieces. Its got a small lip on the inside and is about as big around as my pinky finger. Any ideas as to what it is, and do I need to replace it? Seemed to be working just fine before, minus the slipping clutch which was worn down to the rivets. also its been a long time since I did my last clutch, Is the pressure plate supposed to have a gap before you tighten the nuts or should it sit flat on the flywheel before tightening. There was about a 3/8" gap before i tightened the bolts, now its flat against the flywheel. thanks, Brian
Yeah Im alive. An I really miss the sube world. quarter and a half left of school till Im back! I wish I could find the pic from the back going down that rock. Sorry for the talkin. More pics. Thats a pretty nutty WRX!
should I swap MPFI engine into carbed wagon?
Subafly replied to Subafly's topic in Subaru Retrofitting
well then the guy told me the wrong year cause its mpfi. An ej would be sweet but ...$$$$ not so much. -
Or should i ditch both engines and go ej...probably. -
ok I have a good 92 ea82 MPFI and an 85 ea82 carbed wagon with a bad motor. The guy Im getting it from said its all fubar inside. Should I just swap out the good block from the MPFI making a good carbed motor, or put the whole MPFI in the 85 wagon, which is in beautiful shape which is why I wanna save it. So tear the whole engine apart or rewire? I think it might be less headache swaping the blocks but it would beal cool to have 92 MPFI in an 85 wagon. Any thoughts? This will be my first large project as well. Thanks Brian
friend sprayed WD-40 in his disty! wont start
Subafly replied to Subafly's topic in Non Soob Cars and Bikes Discussion
ya for real. We just let it evaporate out, worked a lot better after that. Turned out his plugs were loose and really dirty. -
Its an Acura integra. He sprayed down the engine with the hose the other day. It was then running rough. He said he thought there might be water in the disty so I told him some WD-40 would fix his problem. I gues he sprayed it in the disrtibutor its self. Now it wont run. I didnt think it would cause problems. Any thoughts? Thanks, Brian
engine swap question, 91 into 85
I suppose so. Just wasn't sure. Thanks how did you get so old noah? -
WCSS 11 Date and Location!
Subafly replied to WCSS's topic in Meet n' Greet. Your USMB Welcome Center
I missed a keg last year?! oh well, I did miss going though so Im gonna try to make it this year. -
Hi everyone been out of the sube world for a while. Im picking up an 85 for $100 with a bad engine and there is an engine on craigslist for 500 but its from a 91 loyal. I would have to swap the wiring harness too right? I dont really want to do that. If I was going to go through the trouble I would stick an EJ in there (which would be really cool.) Has anyone had luck with those cheap import motors? I cant seem to find a good distributor. Im looking for cheap here (aren't we all.) Ive been keeping my eyes on ebay craigslist, and the board. Any ideas would be appreciated. Thanks Brian
Well its been in the teens and below occasionally. My headlights decided to not work. Ended up being a bad ground. Water pump froze cause I didnt do a flush like an idiot,and there was to much water in the system. My windshield wipers suck and only one of my wiper fluid squirters works. Oh ya dead batteries too. but I have four new siped snow tires=not getting stuck
