About Dakotademon7
- Birthday 07/17/1970
Gender
Male
Location
Smyrna Delaware
Interests
Wrenching ,ATV's, almost anything with an engine.
Occupation
Auto salvage worker.
Referral
Google
Biography
I work at an Auto salvage yard and that's where I got my Outback. It was going to be crushed for scrap and I saved it. I thought it was a really cool car and I wanted it. First Subaru I've owned.
Vehicles
98 Legacy Outback.
Dakotademon7's Achievements
Advanced Member (3/11)
2
Just saying hi to my fellow Subie drivers
Dakotademon7 replied to bdspgh's topic in Meet n' Greet. Your USMB Welcome Center
Welcome. Glad to have you here. -
Need some head swap advice/info.
Dakotademon7 replied to Dakotademon7's topic in NA Fuel Injection Engine Tech
Can I get this thread deleted please ? -
Thank you for that advice. I'm still learning this forum. -
No help at all ??? -
I have a 98 Outback with a 2.5 DOHC. There is a 2000 Legacy at my work with a 2.5 SOBC dual port. I'm interested in installing the single cam heads on my 2.5 DOHC block. I tried to search but didn't find any helpful info.
Very cool Outback !
Round Remote Transmitter Programming Instructions 1. Disarm the security system (if so equipped). 2. Open the driver's door and sit in the driver's seat. 3. Close the driver's door. 4. Place the ignition key in the ignition switch and cycle the switch from "LOCK" to "ON" ten times within 15 seconds. Be sure to stop at the "LOCK" position and leave the key in the ignition when you are done. The horn will sound once to indicate that you are in transmitter programming mode. 5. You must finish the next steps within 45 seconds of the horn honking. 1. Open the driver's door. 2. Close the driver's door. 3. Press and release any button on the transmitter. The horn will sound two times to indicate that the transmitter has been programmed. 6. After programming your remote, remove the key from the ignition switch. The horn will sound three times to indicate the system is now out of programming mode. Ensure your remotes work properly at this time
