Silas Cruse's Achievements
Advanced Member (3/11)
37
4x140 - 5x100 Wheel Adapters
Silas Cruse replied to Naked Buell's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Look what I found, good luck. https://www.ebay.com/itm/2-USA-4x140-To-4x100-Wheel-Adapters-1-25mm-Thick-12x1-25-Fits-Subaru-Suzuki-/253945420065 https://www.ebay.com/itm/2-USA-4x140-To-4x108-Wheel-Adapters-1-25mm-Thick-12x1-25-Fits-Subaru-Suzuki-/253945441830 -
Ea82t disty problems
Silas Cruse replied to Crawlerdan's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Does it look like this : rockauto 86 rx -
EJ22T Brat https://www.youtube.com/watch?v=tgs4eY0J4uQ
87 GL EA82 wagon - new to me running problem
Silas Cruse replied to DaveT's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Which pump , part number did you go with ? -
92 Loyale ea82 reoccurring timing issue
Silas Cruse replied to AKLegacyGL's topic in Old Gen.: 80's GL/DL/XT/Loyales...
rotor screw ? -
Subaru GL/Loyale dashboard covers?
Silas Cruse replied to Checkerboard Comet's topic in Old Gen.: 80's GL/DL/XT/Loyales...
This may be an option: https://www.rockauto.com/en/catalog/subaru,1991,loyale,1.8l+h4,1270112,accessories,dash+board+cover,1284 -
Ea Wiper Motor Upgrade?
My 1991 Loyale was slow on the wiper also. So i added a ground wire from the wiper gearbox to the strut tower. FIXED it quite well. -
1991 ea82 Alternator upgrade to 2002 EJ25
Silas Cruse replied to Silas Cruse's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the EJ alternators are mostly 90 amp, and a direct bolt in. just have to swap pulleys, and connect the electrical. and yes i will make those connection heat shrink. -
If it ain't broke, don't fix it. Right?
Silas Cruse replied to Jes1991's topic in Old Gen.: 80's GL/DL/XT/Loyales...
shift linkage bushings -
Subaru Case Brown Who What When How Why ?
Thank you Leeroy ! -
So last week my stock alternator died. I replaced it with my GM 1 wire alternator 60 amp , which i keep for just this type of circumstance. Since the tension bolt does not match up. I installed it with my Redneck wood shims method of tightness. Then on Monday i was able to get an JY alternator from a 2002 EJ25, $17.50 Below are the wiring diagrams I used. Now with everything on still have 14.1 at battery.
Weird squeal when disengaging clutch under load
Silas Cruse replied to Nickoli's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Maybe it is the throughout bearing in the MT. Test this: remove the belts. rev the engine. if it still squeaks then is is not the belts or pulleys. it may not be the TO bearing. but is do love tests.
