Everything posted by Silas Cruse
4x140 - 5x100 Wheel Adapters
Silas Cruse replied to Naked Buell's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Look what I found, good luck. https://www.ebay.com/itm/2-USA-4x140-To-4x100-Wheel-Adapters-1-25mm-Thick-12x1-25-Fits-Subaru-Suzuki-/253945420065 https://www.ebay.com/itm/2-USA-4x140-To-4x108-Wheel-Adapters-1-25mm-Thick-12x1-25-Fits-Subaru-Suzuki-/253945441830 -
Ea82t disty problems
Silas Cruse replied to Crawlerdan's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Does it look like this : rockauto 86 rx -
EJ22T Brat https://www.youtube.com/watch?v=tgs4eY0J4uQ
87 GL EA82 wagon - new to me running problem
Silas Cruse replied to DaveT's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Which pump , part number did you go with ? -
92 Loyale ea82 reoccurring timing issue
Silas Cruse replied to AKLegacyGL's topic in Old Gen.: 80's GL/DL/XT/Loyales...
rotor screw ? -
Subaru GL/Loyale dashboard covers?
Silas Cruse replied to Checkerboard Comet's topic in Old Gen.: 80's GL/DL/XT/Loyales...
This may be an option: https://www.rockauto.com/en/catalog/subaru,1991,loyale,1.8l+h4,1270112,accessories,dash+board+cover,1284 -
Ea Wiper Motor Upgrade?
My 1991 Loyale was slow on the wiper also. So i added a ground wire from the wiper gearbox to the strut tower. FIXED it quite well. -
1991 ea82 Alternator upgrade to 2002 EJ25
Silas Cruse replied to Silas Cruse's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the EJ alternators are mostly 90 amp, and a direct bolt in. just have to swap pulleys, and connect the electrical. and yes i will make those connection heat shrink. -
If it ain't broke, don't fix it. Right?
Silas Cruse replied to Jes1991's topic in Old Gen.: 80's GL/DL/XT/Loyales...
shift linkage bushings -
Subaru Case Brown Who What When How Why ?
Thank you Leeroy ! -
So last week my stock alternator died. I replaced it with my GM 1 wire alternator 60 amp , which i keep for just this type of circumstance. Since the tension bolt does not match up. I installed it with my Redneck wood shims method of tightness. Then on Monday i was able to get an JY alternator from a 2002 EJ25, $17.50 Below are the wiring diagrams I used. Now with everything on still have 14.1 at battery.
Weird squeal when disengaging clutch under load
Silas Cruse replied to Nickoli's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Maybe it is the throughout bearing in the MT. Test this: remove the belts. rev the engine. if it still squeaks then is is not the belts or pulleys. it may not be the TO bearing. but is do love tests. -
1991 Loyale Wagon 4wd MT So my 4wd switch has failed for the third time. My local Junkyards, near Salem Oregon often have parts available. I want to try a different solution. My plan to is to install a 3 way toggle in the dash as a replacement for the stick shift button. And then choose an awesome replacement shift knob. I have researched but not been able to find a diagram of this system. I did find some 1988 Justy stuff but only the vacuum/mechanical, not the electrical. Note: Direct vacuum to each diaphragm line does work and actuate the 4wd , I heard the clunk, and saw the green 4WD light on the dash. I am looking for the wiring diagram. I want to know this: Switch wire -3 - white , red, yellow wire from firewall - 4 - blue, green/yellow, black, black (2) . plug:plug to vacuum switches black black, white white. vacuum switches 1 has 2 black , 1 has 2 white.
Just found these on the website. https://www.lesschwab.com/tires/products/city-r202?size=165-82-13&li=82&sr=s&pn=12966 They are stock size for my 1991 Loyale , 165SR13 Any opinions?
Regular Car Reviews: 1991 Subaru Loyale
Car Was Running Fine Now Won't Start
Silas Cruse replied to jread's topic in Old Gen.: 80's GL/DL/XT/Loyales...
LOOSE connections several check the Fusible links (with 12v test light), inspect the relay plugins ( listen and feel for Click when key is switched on ), inspect for broken Vacuum lines ( the runs only when foot on pedal ) is a symptom on Too much air during idle NOT being metered -
This looks cool. Anyone Use it ? http://www.amazon.com/Tool-connection-1578-Drain-Plug/dp/B00FECIE66/ref=sr_1_1?ie=UTF8&qid=1429591670&sr=8-1&keywords=13+mm+square http://www.lasertools.co.uk/item.aspx?item=420
Potential annual costs of Brat ownership
Silas Cruse replied to Benny Poo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
B.R.A.T. Brought out Another Thousand -
check this 1981 out could be near you http://row52.com/Vehicle/Index/JF1AM43B6BB442856
http://portland.craigslist.org/mlt/pts/4953127240.html
