Everything posted by Silas Cruse
amusing video STi vs stickbomb
Silas Cruse replied to Mykeys Toy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
way fun! -
question about a GL 10 4 door sedan
Silas Cruse replied to angerthis's topic in Old Gen.: 80's GL/DL/XT/Loyales...
vin ? -
Gen 2 Brat - Roll Bar Mounting Points
Silas Cruse replied to thornleyjacob's topic in Old Gen.: 80's GL/DL/XT/Loyales...
https://www.google.com/search?q=Brat+-+Roll+Bar&es_sm=122&source=lnms&tbm=isch&sa=X&ei=M0_mU4OSMcrGiwLQwYC4Ag&ved=0CAgQ_AUoAQ&biw=1440&bih=783 -
Replace the alternator bearings and clean / rebuild the alternator. Cheap and easy preventative measure. Also replace brushes. Great time to paint or polish the alt case.
EJ22 - Carburate, or replace ECU?
Silas Cruse replied to BirdMobile's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Rear Bumper Removal
Silas Cruse replied to The Dude Abides's topic in Old Gen.: 80's GL/DL/XT/Loyales...
1 - Remove both fans. 2 - Air ratchet, and 6 inch extension with 6 sided socket NOT 12 sided as they tend to round off nuts/bolts. -
suggestion put turbo parts onto rebuilt long block, sounds like fun
Long ea82 road trip opinions please?
Silas Cruse replied to LoyaleSmith's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Deer whistles, active Deer whistles !! Like this: http://www.amazon.com/Hopkins-27512VA-Trailblazer-Electronic-Alert/dp/B0000DYV3N/ref=sr_1_1?ie=UTF8&qid=1405145939&sr=8-1&keywords=27512VA Or something like it. -
Spare Tire Mount Question
Silas Cruse replied to JustGo_GL's topic in Old Gen.: 80's GL/DL/XT/Loyales...
So I recently replaced my passenger inner and outer bearings, seals and cv axle due to cv axle noise. Soon after I put 185/80/13 tires on, there were junk yard $10 tires. Now EVERYTIME i start out i make a burout / tire skreech sound from the driver's (left) tire. It did happen be fore the repairs. but only when going up hill from stop, mostly turning right. Question: Do you guys running the 15" wheels and big tires have this problem? tyia
fuel pump pics and prices and octane rating
Silas Cruse replied to jono's topic in Old Gen.: 80's GL/DL/XT/Loyales...
What we all need to calculate is the "Cost per mile driven" Lets say we average 25 mpg at $4.00 per gal tank is about 15 gallons therefore $60.00 per fillup gives approximately 360 miles 360 miles / 60.00 dollars = 6 miles per dollar driven (on average) Then we have to see the difference that the higher Octane fuel gives us in out mpg, Then we can SEE the actual cost of gas. ........ So let us all collect data and truly see which octane gives us the most Value. -
Timing belt's walking off...
Silas Cruse replied to DiveH's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the crank shaft should have metal guides (discs) which align the belts. -
So I removed the strut rod to allow for easier access to the cv-axle replacement. After tighten the 3 bolt that hold the strut rod mount plat to the frame / uni-body There is now a clank and i can see the plate moving when I bounce the car. It clank whenever I drive forward and / or when i hit a bump. Feels like the bolt stripped the nut off the sheet metal, INSIDE the uni-body. Question: Are there captive bolts inside the sheet metal? How screwed am I at a quick fix to this ? Will I have to cut open the sheet metal and weld up a bolt and bracket to fix this ? Video of movement and a little sound: https://www.youtube.com/watch?v=YcVGhVMevRs
EDIT Mountain Tech has one getting it now Please help, 1991 loyale power steering Last night my steering failed. The castle nut on my right outer tie rod failed. called all of the portland area auto parts stores. NONE available until monday afternoon. If you have a good used one please help a brother out. Thanks, Silas
nice find!
90's Loyale Mileage/ Purchase info
Silas Cruse replied to DJA's topic in Old Gen.: 80's GL/DL/XT/Loyales...
http://portland.craigslist.org/clk/pts/4446956521.html -
Maxima alternator charge issues
Silas Cruse replied to ystrdyisgone's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Trudat !
