Gender
Not Telling
Location
Denver, CO
Biography
I have multiple Subys. Doing a Subaru/Vanagon conversion at the moment...
Vehicles
Subaru Outback 2.5L 2008, Subaru Legacy 2.5L 2001
coclimber's Achievements
Advanced Member (3/11)
0
True that! Here's what I did. It's actually in the engine bay and protected by a water-proof box. Still, I'm super paranoid! Putting the ECU in your Engine Bay: http://westycamper.blogspot.com/2014/04/subaru-ecu-placement-rear-passenger.html How to build an ECU box for a Vanagon: http://westycamper.blogspot.com/p/ecu-box.html
I am looking for a back-up ECU. I have a 2001 Subaru Legacy M/T ECU with the following ECU code#: 22611 AD86F When I searched online, I found an ECU from a 2000 Legacy: 22611 AD86FRA Is this compatible? What is the "RA" at the end all about? Is there a resource online that charts all the compatible ECU #s so I can broaden my search or do I have to stick to EXACTLY my code? Thanks Jason
Fairtax4me - Given what you said around the Subaru ECU limiting to 120 mph, it seems like this is what is happening: When the VW speed is 80 mph, the Subaru VSS is 120 mph because it is so inaccurate. So, @ 80 mph (e.g., 120 mph to Subaru), my van violently chugs because the Subaru ECU limiter kicks in. Sounds like a computer/VSS problem and not fuel starvation from say, a bad fuel pump.
Hi! The transmission is VW 4 speed with a fly wheel and adapter plate to make the Suby engine connect to it properly. Speed is configured like this: 1. VW speedometer cable is connected to the front tire and calculates speed based on rotations. 2. Speedometer cable goes to VW speedometer 3. Fast Forward Automotive's VSS is digital and it plugs into the back of the VW speedometer to get a signal from it. 4. The VSS sends a signal the Subaru ECU understands. It's signal is sent to Subaru ECU in back by the engine. The VSS is 8 pulse, which FFA advertises as accurate for Subaru within a few percent, but it is off by 37% @ 55 mph and now I hear Subaru likes 5 pulse VSS signals, not 8 pls, so, false advertising!? Dunno .
I swapped a 2001 Subaru legacy motor & ECU into my 1986 vanagon. The VW speedo shows wildly different speeds than the digital VSS I installed to talk to the Subaru ECU. For example, at 55 mph the Subaru ECU shows 75+ mph. What is happening now, is I run it to 80 mph (VW speedo) and it is showing about 120 mph on the OBD2 mph gauge... Then, the engine bucks wildly like it is getting fuel starvation. I'm wondering if the Subaru ECU has a limiter on speed that kicks in around 120 mph? Jason
Hi! Trying to wire 2001 Subaru cruise control into my van. I have all the CC parts and wires, but they are all cut. I've been told there is 1 wire that goes from the cruise control module (brain) to the Subaru ECU, but I cannot tell from any factory diagrams or charts I have in my manuals, which one it is. 2001 Subaru Legacy 2.5L, MT Is there a wire that goes from the CC module (brain) to the ECU? Is the PIN 19 (Vehicle Speed Sensor)? Thanks! Jason
Thanks to everyone on this forum who helped me get my Subaru/Vanagon conversion project this far! Still lots to do, but at least she started up!! ================================================= Excerpt from my blog post on this @ westycamper.blogspot.com ================================================= The virgin start of my Subaru/Vanagon conversion went like this... With fire extinguisher in-the-ready, Paul told me to give it a shot. The first key turn was a dud. Paul asked "did you do anything around the fuse box?" Why yes... Yes I did! I put in high-powered head light relays under there and ended up dislodging the main power cable from the battery. Ooops! With his electric sorcery, Paul troubleshooted the issue and we figured out where to re-connect everything. To my defense, the Vanagon fuse panel blows. Haha. Literally. On the second key turn, it fired right up. As we celebrated, it puked gas all over the shop floor! Evidently, I didn't tighten the fuel return hose very well Thankfully, I turned it off before we needed the fire extinguisher. But, as they say, third times a charm! Thanks, Jason
Hi! Yes, the Subaru is 2001 Legacy 2.5L. After researching the van wiring schematics, it appears that relays, etc. are all on the VW Vanagon side of the wiring. The van can handle things like fans, low pressure in the AC and adjust too. So, I think all I need to do is splice together the ECU AC Switch wire (green/red) with the AC comp (clutch?) wire and then finally connect a single wire to the van's 12v, A/C wire. If that is the case, it is going to be easier than I thought!
Can somebody please confirm/comment on (e.g., re-fine) my understanding of how the Subaru A/C compressor and ECU work. As a background, I'm in the middle of re-wiring a Subaru harness to work with a VW vanagon, so I'm trying to figure out exactly how the Subaru wires and Subaru components will integrate with my Vanagon A/C wire and dash controls. Here's my understanding of Subaru >> When the driver pushes the A/C ON button: 1. A signal is sent to the A/C compressor to turn ON. 2. The A/C compressor get its power from the belt system (not a wire). 3. A signal is also sent to the ECU to tell it that A/C is ON. This allows the brains to control idling differently while AC is on vs. off. The process is the opposite when the driver pushes the OFF button on the dash. So, there are two wires. One goes to the ECU One goes to the A/C compressor Is this a correct understanding of how the Subaru A/C system works, in a nutshell? So, I'm thinking I don't need to wire any pwr wires to the A/C comp. But, I do need to wire the signal wires up. Are the two wires the same gauge? Seems like a simple signal could be carried on a 18 AWG wire easy enough.
Hi! I have this O2 sensor sub-harness off the 2001 Subaru Legacy engine I am converting for my VW Vanagon. I am wondering, in general, what is it for? I mean, why didn't Subaru just make the harness long enough to reach the O2 sensors? Also, I stupidly forgot which one (up or down stream) I pulled this off of. Anybody know? Jason
