25
Everything posted by nipper
Another vote for keep going with it
As i say it is your money, your risk with illegalities and your risk of blinding other drivers. Don't listen to an expert that has been cited here many times before. Also lets ignore that he cites at least 5 references directly back to their sources about how bad it is. So it is not just "one opinion but if you wish to be that way and not click on links http://dastern.torque.net/techdocs/HID/HB1_HID_Retro.pdf http://dastern.torque.net/techdocs/HID/HB4_HID_Retro.pdf http://dastern.torque.net/techdocs/HID/HB1_HID_Retro_a.pdf i am going to drop out of this thread. You have made up your mind, logic and science will not change it sohave fun.
Lots and lots and lots and lots of reasons why not to do it, as it is a waste of money. http://www.danielsternlighting.com/tech/bulbs/Hid/conversions/conversions.html
Defrost only works when I don't need it.
nipper replied to TheGoat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That is quite possible too, it is sticking untill the car warms up. -
Sorry i call them all blend doors sounds better then one of the directional flappy things -
I am going with a vac leak someplace. When the car is cold the (most likely a crack in plastic) opens up and no def. When car is warm from a warm garage, the thing expands and closes the leak. STart by checking the blend door motors (vac diaphrams) with a hand held vac pump. Wiggle them while you have the vac pulled on them and see if the needle moves. Also test the vac resivoir under the hood (i think this has one) if it has one. -
There was a recall for the MC, but this is a booster issue . It is not an uncommon issue either as some other cars do it on occassion for another reason. Technically it is not the cars fault ... IT IS PEOPLE! The mositure from the air inside the car freezes up the valve. The cure for this sometimes is to replace the brake booster but there is no guarentee. Subarus happen by this (thats what sometimes fixes it) or the check valve (thats why sometimes it doesnt solve the problem).
1971 Sambar info/help please
nipper replied to Trainingday's topic in Historic Subaru Forum: 50's thru 70's
http://www.minitrucktalk.com They have a sambar section
