25
Everything posted by nipper
Cold start problem 92 Loyale
nipper replied to Maaak39's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Well give it a real tuneup, but I bet it is the coolant temp sensor that is bad. This sensor tells the ECU to richen the fuel mix like an old choke used to do. The failure to richen the mix in either a FI car or carbed has the same result, no start in cold weather. -
Do'nt read your own posts? :-p "I did replace pass side axle about 6 mth ago" "My 99 obw developed a bad vibration in gear at idle. This developed a few weeks ago" Your words not mine. Yes the pin that holds the axle in is tapered(If I remember correctly) and needs to go in in the proper orientation. Otherwise they can work loose and sheer. If not then it is possible it is a bad axle, it happens.
What it should do is come on as a check, go off, then start flashing if you have a hard instant failure. YOu are in limp mode, so this is much more then a stuck solenoid or failed sensor of some kind. i can send you the OEM diagnbostic procedures, which also includes non-trouble code methods of trouble shooting. It sounds like to me the transmission is blind. It can not sense engine Rpm, road speed and or load. Those three are critical to safe shifting. Third gear is a limp mode, and is a default that has been around since the dawn of slush boxes. Check all your harnesses and plugs.
Everyone gives the ECU too much credit. It has only one purpose, and that is for emission controls. It doesnt car about voltage, because low voltage car doesnt run zero emissions. Traditionally the Bat light on cars in general runs from handy to useless. In subarus they do sometimes do thier job, but get a bit confusing since it lights up the brake light too. They are called idiot lights for a reason (because they are idiotic and as a UI). Only way to get around this is to get a voltage gauge. To my industries defense, there is a lot of competition on the dash board real estate. 99% of the public really could care less about a voltage gauge, or even now, sadly, a temp gauge (I hope that makes a comeback, no reason why that can't be digital on the outdoor temp readout on the dasg). There is also the cost of adding one (a tremendous one as something has to be moved or redesigned to make room for it). Even with the earlier outbacks i had to go JDM to make them fit
Ohms mean nothing as long as it is not showing an open. The sensor is a reluctance type. When the high point on the crank wheel passes under the sensor, it makes an AC pulse, so a analog meter is better then a digital in this case. As long as it makes a pulse it is fine. You can run it without sheilding to get things going, but you need to replace it at some time with a good one. It is really easy to pick up a stray AC signal and since it is a very low voltage AC signal it may cause the occasional miss.
How many miles on the car? Does it make any noises on start-up or when idleing Get yourself a cheap mechanical oil pressure gauge and see what it is reading. Get one that can has the best range below 20 psig (easiest to read) and see exactly what oil pressure you do have. Does your oil smell like oil or is there fuel in it?
Clicking sound?
nipper replied to roger1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
CV Joint.
