25
Everything posted by nipper
expert on mpfi ea81t needed
nipper replied to swampbrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I still say it is a compression issue. DO a weat compression test and lets see what happens. Squirt some oil in the cylinders. Repeat the test, if the numbers do not come up you have to look at it as some kind of valve issue -
Cant dpo anything untill we have squish fixed really. We have suck, maybe boom. Correct the engine timing first. -
OEM or not?
nipper replied to Arty's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Yes they do fail, as many posts here can confirm. Not only in subarus, but all across the auto models. It is just a thermistor, nothing special. -
Another reason it is not for mortals. SOme people don't balance them when they do thier own repair, but personally I feel that is a big mistake. On the older roos, I know they used ford ranger universals (I had one rebuilt locally), do not know what they do now. Like i said get a rebuilt or used it is easier.
Cooler Temp Thermoswitch.
nipper replied to Loyale 2.7 Turbo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
WHy not just get an aftermarket fan switch kit. They usually have an adjustable thermostat on them. Go to ebay and search "adjustable fan switch"- 22 replies
The compression sucks. It sounds like something jumped. Those number should be a lot higher. -
Dun blowed up real good !
nipper replied to moosens's topic in Historic Subaru Forum: 50's thru 70's
That will rub out. If your going to brake something, you have to go big, and you went big. -
Check the wiring and check the vacume motor. Sounds like it is a loose or broken wire someplace. Grab a harness and shake the hell out of it and see what happens.
OEM or not?
Go name brand aftermarket on this part. -
Do you mean as if there is a crack? 1st step with any leak is to clean the engine, wash it down. This hopefully will help you find it. If it looks like it is coming from under the timing belt cover the only thing there to leak coolant is the water pump. If it doesnt check your hoses and around the manifold near the middle. The Idle Air Controller is there and that has coolant in it.
