25
Everything posted by nipper
Postponed It's going to be a good ol Nor'easter with 1 -2 inches of rain 20-30mph winds and rather chilly, so there is no way to even try to make this fun. We can maybe get another in before eveyrthing freezes. The frozen clay is brutal on cars and trucks.
MAy be a wheel bearing. Sometimes you need to le a noise get louder before you know what it is. As long as you feel confident that it isnt TB. You may be able to hear a bad wheel bearing by spinning the wheel while off the ground and listening. It is possible that it needs a little side loading (the turn) to make the noise. Check the backing plates of the discs too.
Do all your tires match and are equally worn. How are the CV joints? The Viscous Coupling is sealed so gear lube has no effect on torque bind. The Test. Find a flat parking lot. Start off straight then turn the wheel to full lock and hold it there, the car should be moving at idle speed. You should be able to do this without lurching or having to fight the steering wheel. If you have either one of theese you have TB.
Another Coolant Leaking Puzzler
nipper replied to Petersubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thats what i am leaning towards, is a crack someplace allowing water to escape. When you let the pressure sit overnight remove all the plugs and crank the engine, just in case coolant has leaked into the cylinder, hydrolock aint pretty. -
Sometimes you need to let the car sit overnight or many hours pressurized. White smoke I cant judge, but put your hand up to the tail pipe and see if it smells like antifreeze or funky. Try a vacume gauge reading and see what that comes back as. When you check the plugs is one more cleaner then the others? You may still have a sneaky external leak which sometimes calls for a dye and blacklight to find. You can be loosing coolant from a manifold gasket. -
Bumpity, time is a waistin, and the outback board is making USMB look bad as there are 2-3 people comeing from there,
Rarest Old-School Subaru Part or Option?
nipper replied to Loyale 2.7 Turbo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
SUbaru Justy dash clocks. -
The two things that (well three) that will go without any real warning that will strand you on a subaru: Battery Timing Belt Alt Everything else the car will still move and will give plenty of warnings. If it make s you feel better at 290K Blu has only been on the hook once, and that was an Alt on a long road trip at 191,000.
