nipper
    25
Everything posted by nipper
  1. Just an FYI, the sensor must be prefectly cylindrical in shape. With time they may loose their crisp edges they will not function properly.
  2. There is not a reserve tank. Subaru calls this a "jet" pump, it is just a simple syphon with a fuel sender, The senders are wired in series. Another source for the gas smell is a bad fuel cap (i just went through this).
  3. Stick with 16psi. 19psi can cause (even good) hoses to blow, old radiators or heater cores to leak, or even a waterpump seal to go.
  4. We need the exact tranny code and engine codes. Subaru switches all go to ground. Essentially the FWD fuse is a switch, that closes a circuit that signals the TCU to hold the solenoid open. Your solenoid is not opening, and like said above, is fried. before you fix it, check your tranny fluid. If it is clean your clutches may be ok, if it is burnt the (awd) clutches may be damaged.
  5. Tires can make a hige difference to start with. The amount of sound insulation may be more in the Lego then the Forester. When was the last time the diff lubrication wa schanged? Are the tires cupped ?
  6. On a sooby it would be the clips that failed. Failure to replace the clips will cause a clutch issue (why they are not included in the kits who knows). The clips failed for whatever reason and caused all those nasty things.
  7. Yes it can. Easy. Jack up the car and turn the wheel, then turn the steering wheel and do it again. Listen and feel for any wierd noises, Shek the axle and see if there is any play. Can also be tie rod ends.
  8. Also these are basically little microphones, you may have changed how it listens for ping. Water happens, especially when you go wheelin
  9. Nope. It is phenalic (sp?) which is a kind of plastic. Many many cycles of expansion and contraction from heat and vibration eventually catches up with some of them and they crack or fail.
  10. eek! felpro head gaskets? Piston slap goes away after 5 minutes or so. A leaky exhaust may do that too as the parts heat up and close the gap.
  11. http://www.autoblog.com/2011/10/03/2012-subaru-impreza-first-drive-review/#continued
  12. That is what I thought, thanks. It is basically the same system as other 80's vehicals, just the justy has an oddball cat and i wasnt sure. All elose fails it is an OBD1 system and my mechanic has always been good at *ahem* guiding older vehicals through inspections
  13. http://www.dslreports.com/forum/r21883344-Tech-Review-The-Long-Waited-FRAM-OIL-FILTER-REVIEW http://www.corolland.com/oil-filters.html http://www.ntpog.org/reviews/filters/old_filters.shtml http://minimopar.knizefamily.net/oilfilters/opinions.html
  14. Here in NY older cars only go through a tail pipe test. The Justy has an air injector right after the cat (which is bolted onto the exhaust manifold). The replacement system has a modern three way cat that goes where the single stage cat is now (think resonator type placement). I have to loose the air injector for the replacement system. Those who have removed the air injector, do you still pass(non CA) emissions?
  15. No thats normal actually. Minr stopped doing that last week which i thought was odd, now i know. The cap itself became the vacume leak
  16. Blu is a 97. he does not have a pressure senssor (CA cars may) on the tank to throw a tank code. Ocassionally i would smell a heavy gas smell. Today Blu developed hesitation. At parking lots speeds it felt like someone was pulling him back then letting him go. I checked all the fuel lines and smelled a we bit at the filler neck (EEK). I noticed the cap stopped venting when filling up. For 9.00 i figured what the hell and replaced the cap. All issues solved. I knew a bad cap would cause a gas smell (mine would come and go so hard to track down) but did not realize it would cause runing issues. Thinking about it with the closed evap system basically the cap caused something similar to a vacum leak. So just passing this on as an FYI.
  17. CLutch test: Put front bumper against an IMOVABLE object (old tree or building) Set parking brake Start car Shift into the highest gear you have Let out clutch and do everything in your power to keep the car running. If the clutch is good it whold immediatly stall. If it runs at all for any lenrth of time the clutch is on its way out. If you can keep the car running do not keep running the test as you will cook what is left then your clutch
  18. D to N and to D no revers to neutral to drive no Neutral to reverse yes Downshift yes upshift no.
