25
Everything posted by nipper
The shuddering and slipping when loaded is telling you you need a cltuch, it is also slipping under load in top gear but it is so minor you can't really notice it. The slipping clutch MAY be throwing out heat MAYBE causing it to get hot, but in all honesty this is the same type of construction as a wheel cylinder so it can handle the heat.
Light squeal/whistle noise with clutch?
nipper replied to 81EA81's topic in Old Gen.: 80's GL/DL/XT/Loyales...
See thats why you can't have nice things, you keep busticating them -
Block heater?
nipper replied to kanurys's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
They shold be available in Europe, as I have heard it gets cold up there too. I prefer the block type to the oil type. The block type heats up more surface area where the oil one basically does only the oil. The oil sits in a large pond in the bottom of the engine. Neither one is perfect, perfect is both. -
Just leave them be. They have been there happily for 300,000 miles they may not like being disturbed.
A cutch is engaged when you activate it, a clutch is disnengaged is when you deactivate it. A clutch's puprose is to disconnect power, as opposed to connect power, since if no one fiddles with it power is transmitted as it's natural state Noises like this come and go with weather and how loud the stereo was turned up. How many miles on the clutch? -
Could be- Alarm Main relay Ignition switch. Bad battery cable Bad ground(s) Next time it happens (amuse me) put the car in neutral and try to start it. There is not much bewtween the battery and the starter on this car hence why I am leaning towards a cable ground or ignition switch or main relay. Also those would kill the car.
It is rattling around on the fork. This is not an uncommon noise and like I said it can be ignored untill it gets worse or you do a clutch. Tis is a miata board but just an example that it happens. You can also find it mentioned on other makes. It is an annoyance. http://www.rx8club.com/archive/index.php/t-7404.html -
Is this possiable or did i do the math wrong..
nipper replied to subie94's topic in Meet n' Greet. Your USMB Welcome Center
I can get 34 at 40mph so it may be possible -
Isnt there one of these already? It is thge throw out bearing. It can be lived with for a while but eventually a clutch job is called for. -
Digidash temp gauge reads high
nipper replied to presslab's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Mine woulod change one notch too, but that is better then running in the red! -
Interior Pictures: Lets see them
nipper replied to stephen115's topic in Old Gen.: 80's GL/DL/XT/Loyales...
1989 Justy -
Did you try posting the image link? It will post the pic.
