25
Everything posted by nipper
Interior Pictures: Lets see them
nipper replied to stephen115's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Im not sure if i want to burn my eyes out or get pink flamingos for the doors -
The car is normal. Tis is why they did away with digital readouts, too much info Your temp range during the year will range from 175 (baby it's cold outside) to 210-215 (Baby its hot out in death valley). If yours was sticking open you would be hard pressed to reach 180 or it would take a really long time.
Oppsy someone needs to fis something
When is the Turbo supposed to engage?
nipper replied to jeryst's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yes it should come on. You may have a sticking boost control valve (forget the exact name right now). -
General Carburetor question
nipper replied to crazyman03's topic in Non Soob Cars and Bikes Discussion
AT the time most pickups were full size and getting 13-15. -
ABS in gerneral does not work well on icy roads, and i will not get into the ever continuining debate about subaru ABS. ABS is for more rain and slush then anything else. You have a manual so really you should not have the usual abs "issues" that others seem to have since you have far practice in down shifting and haveing two ways of putting the car in N to hel the abs operate. But yes you have the two issues and one sensor.
Now three people have stopped by my house wanting to buy the Justy, and it isnt even running. One wanted him for a winter car, no way in hell, he is rust free!
You didnt quite answer my question. Fill procedure for any car: Remove cap Start car fill cooling system Wait for t-stat to open (will be a rush of coolant maybe some overflow) Top off coolant fill resivoir to hit line Replace cap, drive, let car cool off Check coolant Sounds like you had an air bubble.
6 year oil change interval for reals
nipper replied to bheinen74's topic in Non Soob Cars and Bikes Discussion
You dont need to start the engine twice a month, just cover the air intake so moisture wont get in it. Oil sitting for six years, I wouldnt drive on it as the additives may have broken down from being open to the air. The fuel vapors from the last operation and moisture can make an acid. Odds are you are ok. What i WOULD be worried about is the fuel system, coolant and brake fluid. -
New Guy, First FOREIGN car! haha
nipper replied to AWDWagonator's topic in Meet n' Greet. Your USMB Welcome Center
Welcome. The car isnt all that foreign as it is built in Indiana. ALways make sure all the tires match otherwise you develop the dreaded torque bind -
Subarus dont burn coolant they tend to vomit it. Is it the proper cap? Have you given the system a really good flush? How did you fill the system? Any bubbles in the coolant after the car is warmed up How is the heat? Are the cooling fans in one peice and operative Is it a subaru t-stat (if they are available for this, I do not know).
Water temp sensor moving with revs
nipper replied to apg39's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Check your alt output as the voltage flux can cause this. Also if your electric fan is dying and drawing too much current. I had this with a digital dash, i imagine it could happen with an analog as that is the only thig that changes that quickly with engine rpm. Even a coolant fault wouldnt respond that fast. -
I'm going with a bad clock spring. This is the only moving part which could come and go. An OBDII reader ONLY reads engine related codes, nothing else. There is a way to pull these codes but like the dealer said, the fault has to be present. What happens when you turn the wheel lock to lock or bang on the wheel or column.
I wouldnt do this to a car personally. Plowing snow is very hard work on a truck, let alone a car.
I use the three ton ones from sears myself. That is three tons per set which is more then enough for almost any car or suv. They are cheap and a good name
Well if it hasnt been replaced in ages yes.
