25
Everything posted by nipper
If ti was breaking up I would have some, but since it is just cutting out, i am not sure. Usually if the engine looses power as the load increases (goes up in gears) it is usually an ignition issue. This needs a really good diagnostician. Hrm Hrmmmm Get a fuel pressure gauge and check the pressure when it happens. You may have a fuel pressure issue from the pressure regulator, i am just guessing and out of ideas. You need air fire and fuel for suck squish bang. You have suck, you have squish, it is left to bang. The way the iggy sysytem works if it works in 1st it should work in all gears unless maybe fuel delivery is not up to snuff?
The Justy Replaced the timing belt (and still got it off by one tooth) - will adress that after vacation Adjusted the valves (sort of useless now) Cleaned rebuilt carb of all the crap from the fuel line - He started but won't idle, see previous f*ckup Cleaned out the interior from all the work Blu PS rack 4 tires A bath
Who wants to double pump in a panic stop, when the internal pressure is the highest. First fix the dragging caliper, next make sure the rears are free. They must move freely, not just a little freely. even if they feel fine clean the pins anyway. Even with a heat gun , i would still check all 4 calipers and clean all 4. With a stuck caliper pumping the pedal sometimes helps, and can mimic a bad MC.
exhaust vibration sound
nipper replied to 03Outback's topic in Meet n' Greet. Your USMB Welcome Center
check heat shields to start, they are prbbly loose. Any CEL?
