nipper
    25
Everything posted by nipper
  1. Just because the car has low miles on it does not mean it escapes the ravages of time. I have an 89 Justy in my driveway with 30,000 original miles so i know about these things. Did i miss the brand of tires on the car?
  2. Once this is settled never ever ever go to them again, cause they do not know anything about cars. Subarus do not have unequal length CV shafts. They are just out of answers and are BSing you. There are cars with TS, but quite a few of them have engineered it out. You caught them in a lie. I wouldnt even trust the wheel alignment. You need to have that axle addressed before winter. Winter will destroy the cv joint. Have the front end inspected by someone else, lets rule out issues the idiots may have missed. This can be a bad tie rod, busing, or ball joint. Wandering tells me a b alljoint or tie rod issue. What kind of tires did you buy from them?
  3. You can't lock the kids up? And arent some of the conversational topics a bit adultish?
  4. Last I remeber Connie did not live that far into the sticks...... Just what kind of party is this and do i need my 270lb body guard
  5. i'm still not sure. i screwed up my back and have had a painful nerve issue, so i will have to see whow i feel after the Dr.s office. Dr is 11 am so thats put me at 1 ish?
  6. That should be fine but if you have your doubts, buy a fresh can.
  7. The Justy has maybe run an hour since i got it. The wires are brand new. I just took them off to remove the plugs to install the timing belt. MAN O MAN even they put up huge fight.
  8. Piston slap. Stop using cheap oil. Do the math you really do not save all that much money over time.
  9. I'm just going to lurk here as I do not have a foresster manual. From past exp i now sometimes metal parts in rubber parts can puy up one hall of a fight at times.
  10. They did have the highest HP per L at that time. Even the CVT would beat anything off the line till 30mph. 3500 lb winch on a 1700 lb car, i want a video of anything you pull out I will keep my opinions on looks to myself
  11. Refresh my memory in the AKA part. i really won't know until the last minute if i can go.
  12. How many miles. Failed racks either leak like seives, or you have to wait till winter to find out. When the car is cold, they will be like steering through cooled lava until the PS fluid warms up. My guess would be the universal joint in the steering column is going bad, a common failure.
  13. The avantage to a lifted Outback is the plugs are actually fairly easy to get to, and room to work on the #3 which can be a problem child. My boots are not frozen to the plugs, as i can rotate them 189 degrees with no resistance. I cant get the $#!##$&*& things off. In fact i threw my back out trying to do it under the car. I was pulling and just at the wrong angle. I have has this issue before but on an upright enginhe where it was easier to use brute force or leverage or both.
  14. You must not live in a metro area where there are car theft rings that steal high end cars (or other cars) to order to be shipped to other countries. The steal them from lots and off the streetIn a multi million dollar operation this is chump change and getting a hacker to do it is not very hard as they have them hacking bank accounts and other networks. Legality of equipment is a moot point with them.
  15. Actually i have been waiting for this, it was only a matter of time before a car or cars got hacked.
  16. http://www.autoblog.com/2011/08/05/hackers-prove-they-can-break-into-subaru-outback-via-texting/
  17. For the record "cats gone bad" can mean anything depending upon ones definition. Now The timing belt issue is a FIX IT NOW before you even pick it up if you buy it. The Cat issue is most likely a bad O2 sensor. This is about the right mileage to need one. I do not like it. The car was not well maintaned. They may think fluid changes cover it. If it was well maintained the TB would have been done ages ago. Things don't sound right, find another car.
  18. It is a piezeo electric sensor. Think a microphone on a old portable cassette recorder. This makes an AC signal and sends it to the ECU where the tiny men with the fast calculators figure out what to do next. They get hairline cracks in them then are worthless. They are under rated. A knock sensor hears knock before you do. It is important that this functions as it really protects the head gasket from little hot spots. Ping has a another cause and can be annoying but harmless. Ping is another post.
  19. I have an 89. The problem with these cars are two things. Subaru says to change the oil at 7500 miles which is INSANE on a little over 3 qts of oil. 3000 mile changes and anything you can do to add capacity is great. I added a external filter (Ford truck holds 1 qt) I also added an engine oil cooler with a thermostat. That bought it up to over 5 qts. You really need an oilpressure gauge. The press switch is set at 3 psi which is incredibly low. The weak The auto tranny is a wonderful tranny IF it was not abused. There are CVTs out there with over 100K on them and Justys over 200K. What will kill the CVT - an owner who never read the owners manual. You must come to a full stop when chainging directions. A rolling direction change will split the main pressure drum. This is repairable by opening the tranny and welding the drum. There are not a lot of parts in these, so they can easily be rebuilt. There are two forward "gears" on the selector. There is D and Ds. IN Ds this is amazingly little car. From 0 to 30 it will beat anything off the line. Ds is drive sport. This lowers the starting ratio, This is used for stop and go traffic, going up hills and for engine braking. If this is not used people cook the electric clutch which is how they got a bad rep. At the time it was the most exp car in this group, but alos the largest and most powerful. It passed all the crash tests with flying colors. There are very few parts that can not be had new or used. The exhaust system must be made, but the mufflers ar available. The main exhuats hange always breaks, but a solid pipe takes care of that instead of the flexjoint. The stickers are only available in white (hey im trying to do a restoration so dont laugh). The rear struts are really hard to find I think subaru has them still but they are not cheap. The holy grail to find is the digital clock, and the most in demand option is the pass side mirror. The car is easy to work on. The important parts are available new and the others used. All the paint is available. Mine is going on the road shortly He also only has 30000 miles on him
  20. Finally let see if this sticks. I need to find that blu wire and cut it and see what happens. I wonder where is the easiest and best place to do a little surgery
  21. NO code resitor is fine and has always done this. Even the 98 did the same thing, and that was a 2.2 legacy.
