25
Everything posted by nipper
When in doubt, start with a tune-up. Plugs, filters, PCV Valve and see what happens. Plugs can have a dramatic effect. Cruising speed will affect gas mileage. Over 70 the MPG starts to dump, as with all cars. How many miles on the car? You are supposed to get 16/24 so you really are not that far off. Check tire pressures too.
No. The car figures it out in the first 8 miles as you may drive the car (leadfoot) then your wife (leader foot) then a kid (light foot) or any mix inbetween. Each time the driver changes the car has to learn the new driver and aparently it does it in the first 5-8 miles. The hard reset clears it back to a baseline and it will adjust from there. It also proves on another level if you want to start driving for MPG it helps to reset the TCU and drive in the new pattern. http://www.cobbforums.com/forums/showthread.php?30700-Adaptice-learning-4EAT-TCU http://www.fitfreak.net/forums/general-fit-talk/62010-how-does-ecu-adapt-car-driver-2.html O can post more but they all work basically the same way.
I may have found one. It may not (if it works) stop the downshift into 3rd, but it will soften it. I found this by accident. The reason it may work is because the TCU learns how you drive. You will be teaching it a softer way of shirting making it think you have a lighter right foot. Remove the + cable for a five minutes, this will clear the ECU and TCU memories. Put the cable back on and drive the car with a SOFT right foot. From any stop take about ten seconds to reach 30 mph. When coming up to a stop sign or red light coast to the light. Do not drive up to it and brake at the last minute. Do a couple of these at 40 mph, 13-15 seconds to get up to speed. Then do one that takes 25 seconds to get up to 55-60. Do this for about 8 miles. During this you may get one late shift, just back off on the gas, the computer is trying to figure out how you drive. What does this do? It teaches (lies) to the puter that when you need to accelerate for a hill, you are not one to bury the gas when accelerating. What I discovered now is that when going up a will, instead of an immediate 4-3 downshift. it does a 4 - 3 1/2 (unlocks torque converter) then will go to 3 after a second or so. This is generally better for the engine and drivability (read your nerves). I do not know How it effects down hill as I kept having some idiot or another infront of me piddling along at 50 on a 65. It may be my imagination but it seems to have also affected deceleration, making it stronger on the coast. But then again I just had my exhaust system repaired so it may just be me, but I think it did. May work may not but the logic does make sense.
Unless he got it on a dyno, we all have a freind that got something. A real supercharger will use 10hp to 80 (serious drag monster), You cant afford to use that 10 to just make 20 more. Especially on an old engine. Search the net aunder electric supercharger scam and you will see lots of info on it. If it was possible dont you thjink the car compaines would throw a 20.00 blower on the car instead of a 1000.00 turbo/super charger?
Here is a thread from the Offroad boards (sooby) they are trying to make one. http://www.offroadsubarus.com/showthread.php?t=2687
Plumb it, thats why they make fittings, adaters and tubing. When I had one of these that is what I did.
That old they ain't going to be pretty, but remeber that some people feel the same way about our soobys.
Replacing the speedometer with the LCD version.
nipper replied to edrach's topic in Subaru Retrofitting
Hrrrmmm never thought of this http://www.autometer.com/tech_faq_answer.aspx?sid=2&qid=43 http://www.hurst-drivelines.com/popups/speedo_vss.html http://www.vdo.com/generator/www/com/en/vdo/main/products_solutions/commercial_vehicles/tachographs/sensors_and_adaptors/sensors_and_adapters_en.html Ask any major gauge mfg.
