nipper
    25
Everything posted by nipper
  1. Tounge weight is easy, use a bathroom scale and for a boat it should read on a scale. The boat should have a weight tag hopefully someplace or ask a boatyard, same for the trailer.
  2. Blu has almost 300K on him. Nothing you have listed does not go under normal maint, though i would suspect an O2 sensor and not the cat. For 1500.00 where can you get a replacement car that you know that will not require another 1500.00 in repairs. Invest the money. When you hit 500K we will disguss putting her down
  3. 135,000 miles is not premature by any standard for rubber hoses, especially hoses athat are in less then an idea location. Metal lines do fail, again because of enviormental conditions. And there is always, stuff breaks.
  4. hrmmmm
    I don't know many scrap yards anymore, more so in NJ. I know there is an online source for used parts, gregory knows it, it escapes me right now. Try ebay also
  5. i will file this in my mind. Used compressor is much better for the wallet then new. i would price new vs used and a new clutch.
  6. These are (realtivly) cheap gauges, so they not mounted on a free standing pin. You need a specisl tool to remove and reinstall a needle ((and a gentle touch). ALso you need some sort of calibration comaprison. Just easier to replace things
  7. The clusters in these cars are amazingly simple to take out and take apart. Inside they are all modular. There are everal plug in harnesses. There will be one small but tough one in the center(ish) of the cluster which is for the spedo, otherwise everything else is obvious.
  8. The wheel bearing and it is probably chewing up the hub too. Do not drive this untill it is fixed, as from this point on it will just cost more to fix.
  9. Best to do it in the fall past peak tourist ($$) season. Also not all of us have AC The justy should be on the road in a few weeks
  10. Tire cupping, the most likely issue on a car with 100K on it is a bad strut. Wheel alignment will not cause this issue. What is happening is that the tire is bouncing up and down on the road. This can not be seen as it is just chainging the load on the tire. Random cupping will be a strut. Cupping in the same spots will be a wheel balance issue. This is easy enough to diagnose as only a few things cause it. A bad wheel bearing will not. Make sure the tries are mounted in the proper direction. This sounds silly b ut most tires are directional now. Cheap tires can cause it too.
  11. Some soobys have cold start issues and emissions issues that are fixed by a reflash. Not a biggy.
  12. Thats great, i get 19 - 21. I think we have more stop signs per square mile then a stopsign factory.
  13. I will say this then take my ;eave as these posts are confusing. There is no such thing as doing half a rebuild on a auto tranny. You have hard parts damage. Torque bind can either lock up the driveline or "go away" because the clutches are glazed. rebuilding an auto is different from a manual, however as I always say, it is your money.
  14. ALWAYS replace one part at a time, if that does not solve the issue, put the original part back on, otherwise it can make it impossible to diagnose properly. Go back and unplug then plug all the connectors in again. Do you have the VSS operating properly and the MAP sensor working?
  15. Cross your fingers you are blessed. The lockups sound like everytime the car wanted to shift, there was not enough fluid to sequence everything. When two gears are engaged at the same time clunk and lockup occures and the car will not move. Check linkages. but..... If nothing wrong linkage wise and no reverse tranny is busticated.
  16. Moderate gas pedal allowing the transmission to upshift quickly, otherwise realise it is an AWD car and will have good to rotten around town mpg depending on how many stop signs there are..... like here
  17. Depends if it is a manual or auto on what happens when it goes poof. Gegerally differentials whine before they fail or clunk whne cainging direction. On a LSD missmatched tires will make it fail, on a sooby all 4 tires have to match. More then that search.
  18. I did say rare not never, and a 93 is a different beats then a 98. I will stick by my statement and am still curios about the inhibitor switch.
  19. Have any freinds? Have someone move the wheel back and forth while you listen for the noise. Jack up the car and wiggle a wheel back and forth to see if you hear the noise. Usually subaru racks fail by leaking, not by mechanical failure.
  20. The brown dust is normal on an older subaru clutch. Why did you not go to the very first thing to check and not the very last. KISS (keep it simple -----) You are low on refrigerant, as you have a leak someplace. The AC has two pressure switches, one low and one high. They both have to see normal pressures to operate. You have low refirgerant. The refrigerant is liquid at first, as it gets hotter it expands and will not become liquid again due to a lack of refrigerant. If it was a clutch issue they usually don't engage at all. The fact your does (especially for 20 minutes) says it is fine.
  21. Im still leaning towards the inhibitor switch as it is rare for the ignition switch to go bad. Find the pins on the inhibitor switch thsat are there for the starter circuit and jump thme to see what it does
