25
Everything posted by nipper
Really? Who knew. It will be a solenoid of some kind as I cant see the business end of it in the pic.
Try this http://www.vwdieselparts.com/forum/index.php?sid=58d9bbd6eb57866e06a144effd11b387
Hi! 2,5 block (engine) is engineered to the very edges of what it can do normally. You'll be better off starting off with a 2.2 as it is a stronger engine all around.
Injectors or carbed? Ot looks like the anti diesling solenoid for the carb but not sure.
Stinky, noisy, and indestructible. Try the Vanagon boards for some assistance as I think they use the same diesel engines.
http://oppositelock.kinja.com/proud-of-boxer-50-years-of-the-modern-subaru-1737707038
- 1 reply
- 1
My choke on my Justy.
The solenoid may have failed as it is pulsed (hence duty in the name). It makes sense.
- 9 replies
- AT Oil Temp
- Legacy
(and 1 more)
Tagged with:
Coil is straight forward to test fir opens or shorts. Check your harness fr physical damage but odds are given the age of the car it can be a tired solenoid. Just an FYI, the flashing light indicated a failure on the previous running cycle.
- 9 replies
- AT Oil Temp
- Legacy
(and 1 more)
Tagged with:
FWD someone pulled the bulb. There are quite a few solenoids. How are you pulling the tranny codes?
- 9 replies
- AT Oil Temp
- Legacy
(and 1 more)
Tagged with:
If your worried about resale value at 150,000 miles, may I suggest that one never buys a new car. Also consider this, that tire sizes are not an exact measurement (physical measurement is) between mfg's. Who knows if your new car bought today will even survive to 150K (hey its a rough world out there).
It sounds like you may need a new (used) driveshaft due to a bad universal joint. As it is not making a vibration at speed that slowly gets lower with time, inspect that driveshaft now. I am going to assume that its not a tire issue only because this can be a saftey issue. How many miles are on it. FWD fuse isnt going to help at all if it is the drive shaft.
You want to see a naked subaru engine? You want to see a subaru in a Beetle (and for once showing how its cooled) Got it right here
We Post Our Grievances Here
nipper replied to Subasaurus's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Dear Subaru, As a justy owner, please do share ho in bloody hell do you manage to bolt the carb on a justy manifold, or was it all assembled by Asian female children with the tinyest of fingers? -
Newbie with a slight problem
nipper replied to yakmike's topic in Meet n' Greet. Your USMB Welcome Center
Call the Area Rep hes in your Owners Manual. This sounds like its something thats easily solvable with the right tech. -
Burbing the cooling system
nipper replied to Sapper 157's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Fill the cooling system from empty SLOWLY with the engine runing. Allow the T-Stat to open and keep filling, yes with the heat on. Level ground is fine.
