nipper
    25
Everything posted by nipper
  1. Your going to make me read a manual arent you Give me a few minutes, i have to find it.
  2. The two sets of circuits have different feeds. This sounds interesting. Have you checked all the bulbs to see if the filaments are all good?
  3. I never really thought about it before. I guess it would, its a closed system Clutch wear there is really too many variables, but I would expect over 80K miles to the sky is the limit. Just depends upon the driver and where the car lives.
  4. SHifter needs to be in Park OR Neutral to start if an automatic, start there. Make sure the battery cables are tight.
  5. There is the ever dark demon lurking behind the passenger side liftgate boot. Poke there carefully. http://www.ultimatesubaru.org/forum/topic/153009-broken-wires-in-liftgate/?do=findComment&comment=1281190
  6. It is interesting between the two cars. the outback is 19-21 max in my town. The Justy is 30. On the highway the Outback gets 30 (below 70). They Justy gets 36 no matter how hard you beat on it. I choose the Outback for long highway drives, the Justy for congested drives.
  7. 2005 Outback, if I keep it under 70 I can get 30 mpg. Around town it can be 18-22. We have stop signs on every 1000' long block and traffic lights everywhere.
  8. Well lets not be so pickey about names An automatic in a subaru has an "inhibitor" switch. This tells the car what gear it is in Manuals will have a clutch switch of some kind, and sometimes a neutral safety switch on the transmission. More modern manuals may even have some sort of switches to tell the computer what gear you selected. Someone may have bypassed your clutch switch. Not uncommon.
  9. Ohhhh i never thought of that. I think its off I will check tomorrow.
  10. My 2005 outback, the passenger side seat belt pressure switch is stuck. If i engage the seat belt it stops. Normally I wouldnt care but I know the airbag does. Is this sensor/switch replaceable?
  11. Leaking anything actually. Wash off the bottom of the engine, top off all the fluids and go for a drive. Then park the car with cardboars under it and see what the stains are.
  12. The coolant level will change a few inches during operation. It gets sucked back in to the cooling system as the engine cools off, unless the "sealed" system has a leak of some kind. A leak can be a hose, the radiator or the head gasket. Are the bubles you seeing large and continuous?
  13. Has your PCV valve ever been changed? Spilling coolant winter or summer is not a good or acceptable thing. Where are you seeing the milky oil?
  14. Its actually a moving target. As subaru rectifies Hg issues, they update and superceed previous ones.
  15. YAY way cool. I *ahem* have a friend that can use some *ahem* stickers for his Justy
  16. Head gaskets are complicated things. internally they have to seal high combustion pressures and temps, seal a water jacket at 14ps, deal with external temps from -50F to 150F. They have to deal with fast moving air, high flow water, and oil up to 80 psi. If your lucky all will work well. If not you can get an external leak of coolant or oil (which on subarus one can live with unless its driping on a hot exhaust). If you are unlucky they will fail on the combustion side. Like Imdew said DOHC tend to blow in the worst way possible. SOHC tend to weep oil or coolant. Weeping can be tolerated if you keep an eye on the fluid levels. Weeping wont strand you, a combustion side leak will.
  17. NONONONONONONO nVEVER use the oe jack except for chainging a tire, and even then be careful. I used ramps last time I tried doing this.
