25
Everything posted by nipper
Advise needed
nipper replied to Zimogor's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
This is a CV joint, as ball joints or tie rod ends will cause wandering or groaning noises. -
Transmission Predicament 1980 BRAT
nipper replied to Scooner's topic in Historic Subaru Forum: 50's thru 70's
Transmissions, the #1 car repair ripoff "we cant tell till we take it apart", #2 is bad cats (but usually due to lazy techs). It depends upon how far they tore it down. My guess is yes as i doubt they took gears off the shafts to rebuild the synchros. My question is how would you know you got all the parts? -
YAY A JUSTY! Pull the cap, is it nice and dry, does the rotor spin freely (bad thing). Is the timing belt in good condition (easy to replace). Get yourself a factory manual. These are easy cars to work on.
Read this first http://www.thetruthaboutcars.com/2015/03/piston-slap-traversing-world-led-retrofit-bulbs/ I would really go back to light bulbs as they last about ten years, and that illumination control is not cheap (it is in a junkyard get a few of them). Is the entire dash out, or just sections of it. Does your glove box light work (its run by the illumination controller)
For those of us who are running older cars (much older) keep an eye on ebay from time to time for emission and fuel related parts. I got a bleed valve for the Justy dirt cheap compared to the new price (and it was OE). The Justy had a rough idle i couldn't trace (it is a 3cyl), so i lived with it. During the winter the bleed valve popped up on ebay for like 12 bucks (70 new). I figured eh can't pass it up. Come spring I swapped it out just because and the rough idle went away, even though the part was working well. It was just tired from being almost 25 years old. So if your running any older car, snag arts you dont think you need (that are new) because a new part sitting on a nice shelf someplace is in better condition then one that has been living under the hood for 25 years.
Im going with the connectors on this one, otherwise we have to start going back to the ECU as an issue.
- 12 replies
- oxygen sensor
- o2
(and 7 more)
Tagged with:
Because it is a test that would normally be done, unless you have your head under the hood while the car is running (for pressure). http://www.theymightberacing.com/Components/FuelSystem.aspx This car would NOT have a returnless system. http://www.underhoodservice.com/point-of-no-return-returnless-fuel-injection-systems/
Sometimes as cars get older parts in catalogs get condensed so that they may not be quite right. I would still do a pressure and flow test on the system. This is coming from someone who owns an 1989 Justy and has seen what people list as proper applications and are far from being the proper ones. Also check (My memory fails me here I may be wrong) if there is a fuel return line and that it is free and clear. Another way around vapor lock in modern (read obd anything) cars is to circulate fuel in the fuel system so it stays cool. Also waht you may think of as a vapor lock issue is more of a fuel starvation issue. Have you fiddled with the fuel lines or emission controls at all?
