25
Everything posted by nipper
Heat does wierd things to cars, and in Az it can be dramatic. Subarus are known for having the solenoid contacts go bad with time, and this is about the right age. I would also check the condition of the battery and clean the battery terminals. I am assuming here there is no cranking when she turns the key?
The issue goes away with the AC off (car has dual zone auto climate control). AC blows cold It feels like it is over compensating when the AC comes on, and under compensating when it kics out. The rpm does drop lower then it should when the AC kicks out, but it is no where as dramatic when the AC kicks in.
Surely someone has a solution as my poor Justy's seat are all popping at hte seams, and heat cracking in the back.
I havent yet really started chasing this down but it bothers me to no end. 2005 Outback Ltd 4eat, 199,000 miles (6000 ish on engine) This started after the engine was replaced by Subaru. The engine rpm has a wide swing when your sitting in D, stopped, foot on the brake and the AC is on. I would say maybe a 300-400 Rpm swing as the AC cycles on and off. Its enough of an rpm swing you can feel the car surge. I havent had time to start physically chasing it down as life has been cruel to me last few months, but warm weather is coming.
The dreaded spray bottle. At dusk with the engine running (dont touch the car with any part of your body, trust me I know) spray the coil and ignition wires with water and look for sparklies. That is the definitive test. Wires look new they can still be crap wires. NGK plugs thats good. Air filter, fuel filter, plugs, wires, PCV valve are all part of the modern tuneup. Do you have a vacume gauge about?
Crank is ignition so the engine knows exact moment of TDC of #1 piston. Getting this timing wrong can cause engine damage. Cam for fuel as thats less critical and manged differently. It also probabaly has something to do with making a robust ECU and all the coding, and signal noise from an engine. These cars HATE cheap wires. Cheap wires the silicon breaks down very quickly and you get voltage leakage. Subarus are very pickey on wires and plugs, so i bet the wrong plugs are in there too. Get yourself a Haynes manual, they are the best for your car.
Well lets start with a full tuneup, filters, pcv valve wires etc. Is there any way to confirm what had been replaced with the timing belt? 150K is about right for a O2 sensor or two to go bad. Bt really this is not a clogged catalytic converter. It is not a bad converter either. A clogged converter would affect engine performance.
Cam timing sounds off.
What brand wires? Is there any oil on the spark plug boots? Have you checked for voltage leakage at the coil towers? Crank sensor is ignition timing, cam is fuel injection (throttle body) reference. try something simple for now, unplug and plug back in the cam sensor and see if it is as simple as a dirty connection. If it is just doing that usually cleans the contacts.
