25
Everything posted by nipper
Subaru CVT's dont have wet clutches to transmit power, so it doesnt work as hard. The heat from acting as a buffer between moving surfaces is really what beats up transmission fluid. In Subarus case the fluid is used for lubricaiting and transmitting work (moving the drums) so it doesnt get as beat up as other mfg's fluids. The fluid itself I wouldnt worry about, but the life of the additives is what would concern me. http://theanxiousthoughts.blogspot.com/2013/12/the-technical-side-of-continuously.html I have a CVT Justy a different animal, but that only holds 4qts and is much cheaper fluid. It is more important that the fluid stays filled then is changed. It never hurts to change fluids, just on a CVT always use the recommended fluid. The CVT may still be too new for aftermarket fluids yet.
What are you driving?
86 Gl-10 not starting randomly
nipper replied to Wolverine18's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I was going to say the ignitor or pickup in the disty, i have had this issue in the past. -
The buzzing noise ignore. You are hearing a duty solenoid in the transmission do its thing, which you normally wouldnt hear or are used to hearing. The more critical problem. When was the last time the timing belt was changed in this car. Fuel systems on these cars are so reliable we can ignore it, for now.
fixing one problem found another...rusty gas tank?
nipper replied to joe5's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The pebble trick works on many kinds of tanks -
1984 GL wagon won't start.
nipper replied to ErikAnderson's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Also rare but not uncommon, if the rotor is attched by a set screw, make sure the screw is tight. The loose rotor can be another facepalm -
"My knowledge of engine internals can be summed up by this: "lots of spinny bits move about in a reasonable amount of order"" Thats more then most. On the plus side this is a simple engine that is about as complicated as an air cooled VW engine, so the mechanical internal list of things that can be wrong is quite short. Timing gears do go bad, its rare but it happens. You can remove the valve covers and see if all the valves are moving. Is it full of oil? -
May be time for a basic dry/wet compression test. Also a real fuel pressure/flow test. Do you see any fuel being squirted down the throat of the carb when you push the throttle fully down? -
If the solenoid has failed or is stuck, throwing in the FWD fuse will not help, as the solenoid must be powered (energized) in order to be in FWD. The fuse only sends a signal to the TCU to hold open the solenoid. Any model with a 4EAT can develop torque bind due to a failed Duty C solenoid. Not all will have leaking clutchpack assemblies. This also may be one of those few times you may want to give a dealer a shoutout as they would know what they are looking at better if it is the clutch pack pressure issue. It is one of those "while we are here" rebuild the unit, as torque bind can and does damage the clutchpack
