25
Everything posted by nipper
Trailer tires on a Soobie/Small car?
nipper replied to Subaruist's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I am running into this problem with the Justy. I was talking to Tire rack about the situation on a related phone call (insurance claim on the outback for a flat tire). I asked them what if I had replacement insurance on the Justy and the tires in that size was no longer made by anyone. They said that they would pull out their spec sheets and find out what tires wold fit on the 13" rims that are 14's. They said some 14's are like plus sized 13's. Explains why I have seen people struggle with some brands 14 getting tires on wheels and other brands just go right on. I didnt dare ask them about 12 inch tires I wasnt that brave. Maybe I have to get them Europe. -
Do you have an old timing light about? If you do focus it on the main pulley and look for a wobble. If it is really bad, you can feel the looseness of the pully and it may cause a little vibration at idle. Beyond that we need more details.
- 5 replies
- 2004 Forester
- crankshaft bearing
(and 2 more)
Tagged with:
Tires. Tires tires tires. They should all match, be same brand, type, and wear. Once the car is warmed up a bit from driving, take it to a parking lot and do a full lock turn. It should take no throttle or very little throttle and no kick back from the steering wheel. It should just feel normal. Its important to this with a manual once the drive line has warmed up, as torque bind may not show up with a cold transmission as opposed to a warm once. If it passes this test (one of the two reasons subarus may be traded in at a subaru dealer) and the HG's arent leaking externally or internally, your golden. Everything else is just servicing.
push button 4x4 with torn up CV in front
nipper replied to BoostedBoxer421's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I had to for a month or two. My front frame was rotted, it was pulling the CV joints apart. Thsi wont ruion your driveshaft unless your driveshaft already has issues from say age. Its akin to say jogging is no good for you since it killed your 100 year old uncle.- 8 replies
- transmission
- 4x4
(and 2 more)
Tagged with:
I did this in an 89 GL, it will cause no damage,- 8 replies
- transmission
- 4x4
(and 2 more)
Tagged with:
I dont even know if it is possible to replace them all the back to the ABS unit. Its been ages since I had a car do this, and never one where the body didnt match (read scrap the car). You can trace the hardlines back to someplace where it is easy to add a new fitting and line. You can also start (and in all honesty I have never had good luck with this on brake lines personally) soak the nuts with nut buster, then using a proper flaring nut tool, take it apart, inspect, clean, reassemble and see what happens. If anyone here wants to totally contradict me feel free, as I havent had to do this since I owned a 73 Super Beetle.
They have discs all around. Remove the brake booster hose from the booster and stick your finger in it. If it is wet and smells like brake fluid, you have a bad Master Cylinder. This is not an unusual way for a MC to fail. Thats the easiest check, after that look at all the calipers with the wheels off like Gary said.
Ok a few things. Oil change interval is 7500 miles, I tend to do it every 5000 miles, if your ok with 3000 miles so be it You are seriously overdue for a timing belt job, including water pump, oil seals and idler and tensioner. This is a very very expensive repair if not addressed like yesterday. Also you are way more over due for tuneup, plugs, wires, and PCV valve. Air filter too. Any and all can cause what you are seeing.
Whether it is or isnt, it is not an optional thing to do, it must be done, along with thw water pump, seals, and Tensioners. It is possible, and if it is that worn STOP DRIVING IT NOW. Continuing to use it is the differnce between a 750-900 dollar repair and a 2000.00 repair. It can also be spark plugs, filters, wires, which also need to be replaced regularly. I am also afraid to ask, but are you the original owner? how oftne is the oil changed? DO you check the oil level?
I just got a little wet .. VW Diesel Conversion
nipper replied to nipper's topic in Subaru Transplants
the stock 1.6D was only 52 hp and 71 ft/lbs of torque, and a engine life measured with a minute hand, so I would do it in a heartbeat (with lottery winnings). The 1.5D was 48hp! -
http://www.boxeer.com/ee20_vw_conversion http://www.smallcar.com/index.php?dispatch=pages.view&page_id=61 drool. Money, minor detail.
