25
Everything posted by nipper
This is a problem with remote entry. We all do it, even I do it. We dont use the locks so they seize over time. You need to spray the cylinders with a penetrating oil then GENTLY shock the cylinders with the key in the door. Have a duplicate set of quality keys handy just in case. Try each cylinder eventually one will loosen up. I went through this with my 97 when the battery died. You can possibly reach up and pull the hood release cable. It may take multiple attempts, and use a good product, then after that use lockease to lubricate all the rocks at every oil change.
Hard pull when braking...
nipper replied to Mr.Atlantis's topic in Non Soob Cars and Bikes Discussion
Go back and check your work on the calipers. 199 this car is old enough to need front end work. A bad bushing can cause this. -
Coking can come from several sources. -One is never chaining the PCV valve. If you have an engine that tends to coke you should replace it once a year to be on the safe side. -Reduce the oil change interval from 7500 miles (or more on some engines) to 5000 miles. The oil itself may be fine at lubricating right up to and past 7500 miles, but the additives have broken down. -Try a hotter spark plug as you may not be burning off the (normal) residual oil left on the valve stems. This is a problem on direct injection engines especially (Subarus do not do DI). -A different brand of fuel (stop using the cheap gas). All gas is the same but the additives are not. -You may need to actually press the go pedal to the floor once in a while (highway on ramps) to help clean out the carbon.
