25
Everything posted by nipper
Sorry I never saw your response Slipping I asked to get a feel for how long till impending doom, Doing a full flush (3x) nay or may not by you time. The whirring you hear if it matches engine RPM is the front pump. I was hopping slipping in higher gears as that would buy time. Lower gears. However in the words of click and clack GOOD NEWS. You can go and try any shinet can of transmission fix your heart desires now. It cant make things worse, and may buy you time. Just realize that these things always pick the most inopportune time to go belly up.
- 23 replies
- valve body assembly
- atf
(and 4 more)
Tagged with:
A question I should have asked a while ago, when does it slip?
- 23 replies
- atf
(and 4 more)
Tagged with:
Dont be freaked out by the metal shavings unless you can confirm its metal and not any chunks. Chunks bad. I still feel its on the road to doom.
- 23 replies
- atf
(and 4 more)
Tagged with:
Keep in mind its a "duty solenoid" which means it constantly cycles on and off during normal use. People can and do hard wire it with mixed results. Also there is more to the AWD control circuit then just the solenoid. Id the internal housing is worn it can allow pressure to go where its not supposed to and activate the AWD
There we go back to a real keyboard. The problem isnt the valve body, its rarely bad on SUbarus. The clutches are damaged hence the slipping. MAYBE you can get lucky or live on borrowed time by changing the fluid, that may help. The sooner the better.
- 23 replies
- atf
(and 4 more)
Tagged with:
Some resistance ? A bad rack usually leaks or fights you in just one direction. Yes TB is torque bind.
- 23 replies
- atf
(and 4 more)
Tagged with:
Im a bit rusty The sports mode issue can be as straight forward as a bad switch. TB I may have guessed wrong (usual disclaimer car isnt in my driveway) but the rubbing noise, upon reflection that can be a bad tranny mount, but that along with the tranny over heating, slippng, atf light flashing, all hints at doom. TB also covers un-torquebind, a failed clutch pack. How does it behave are you ever fighting the steering wheel?
- 23 replies
- atf
(and 4 more)
Tagged with:
