25
Everything posted by nipper
Ignition Switch getting Hard to turn.
nipper replied to Dinky26's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thats why you ONLY use a graphite lube in locks, it is made for it. WD40 isnt really a true lubricant -
"mini" starter?
nipper replied to Uberoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I think you have some fabrication ahead of you. Looking at mini starter, they show small high torque starers for v-8s, which look about the size of a sooby starter. Google it "mini starter" then select "shop for" where the pictures are, maybe that will help? -
Have you tired using some graphite (lock ease) in the cylinder? Should do it to all the key l;ocks once a year anyway. -
"mini" starter?
I dont know what would fit, but there are starters out there called "reduction gear" starters. They usually have shorter motors and spin fatser, but use a gear reduction to make the extra torque to spin the engine at the right speed. Off hand I do not even know where to start looking for what would fit. However I never really though of subaru starters as being that huge. -
So the car can move on its own now? If so, where can you feel the vibration. Is it throughout first gear or only towards the bottom middle or end of the rpm range? Does it happen in all gears at that rpm or only first and reverse? Wht happens when you go to parking lot and make a full lock turn at idle speed? Do all your tires match Are all the tires properly inflated?
I am preping him for his first major surgery, an amplifier. I have the factory HVAC built into the (2009) Head unit. From looking at the wiring diagrams I can not seem to find a good signal source to turn the amp on. If this works I will decide if I can use that to drive it Or does it need to pull in a relay to turn on the amplifier. The 2009 unit had the SAT option, so I am going to try to find the power source that goes from the head unit to the SAT unit and use that as the signal for the amp. The plan is to mount the amp (sony xplod) under the passenger seat, OR if the measurements work out in the spare tire area. I wish I could find a good wiring diagram on all the connectors on the back of this head unit, as the FSM leaves out all the cables for the SAT unit. I looked on Scoobymods but nothing is listed. Thanks
You popped a cv joint. I bet (be careful) if you put the FWD fuse in the holder, put the car in drive (do not stand in front of the car) and look at the drive shafts, you will see one spinning like mad and the other just sitting there waiting for something to happen. It is the one that is spinning like mad that is broken. The rear wheels are essentially driving the car, the vibration your feeling is the bad CV Joint, and the fluid change, all soobys love fluid changes.
Skid Plate
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Thanks, i will book mark that for later in the spring. -
Blu had a "going" rear wheel bearing for the past 3 years. I got so used to it. Now my 2005, Blu2, is so dead quiet I can hear owls in it (something sounding like a hoot owl in the distance inside the car). It can even depend uon what the road surface is made out of. Usually the choice of tires will make a big dent in road noise, but not always.
anyone use Guaranteed carburetors.com?
nipper replied to old sub freak's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I used them for the Justy. They left parts out. I was very pissed. See if you can find someone local to you they do exist.
