Everything posted by nipper
2005 Outback Power Seats
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow do the handles come off the switches? I found out a weak battery is first to show up in the power seat switches.
My drivers side power seats switches are failing. My best guess is they need to be cleaned. How do they come apart, does anyone know?
Brake Code 42 - High G-sensor friction detected
nipper replied to carfreak85's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI cant get a straight answer on that. But the first step would be to unplug it then replug it in and see if thats enough action to clean the contacts.
nipper replied to carfreak85's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo this has absolutly nothing to do with the telephone shaped dent in the front of the car
nipper replied to carfreak85's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIts the G sensor under the center console in the center of the car. It measures the acceleration/deceleration of the car. Its reading high, you did something to scare all the G's out of it.
Justy
https://www.autoblog.com/2019/04/09/junkyard-gem-1993-subaru-justy-4wd-gl/
They dont make things last anymore
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe line burst. It had been subject to brake recall and was fixed
Lookie!
Ain't it. Almost worth it to flip it as someone stated on the comments
Lookie!
https://jalopnik.com/at-2-300-could-this-1979-subaru-dl-put-a-smile-on-you-1833740024
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI haven't blown a brake line since 1982
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes and I don't know. Tomorrow it goes to the mechanic to find out. I'm having all the lines replaced.
I am thinking of writing Subaru very sternly worded letter. STERNLY! 215,000 miles and I blew a flex brake line. What crap. They just dont make things last anymore
ABS VDC light on dash, when brake is pushed....
nipper replied to BabyFace Fitz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
- 4 speed manual transmission is going out on my 84 GL wagaon
Who is it coming from? Transmission, do the clutch at the same time. I think most would drup the engine and transmission together, but it can be done with the engine in the car.- ABS VDC light on dash, when brake is pushed....
nipper replied to BabyFace Fitz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSockets do go bad with time. I am guessing your cruise control may be angry too. A wheel speed sensor s not happy. Either a broken tone ring or bad sensor, A broken tone ring wont throw a code. Also those codes are not part of the OBDII system so it wont throw any code with a regular reader. Its a common fault mode.- Thermostat Replacement for 1995 EJ22
nipper replied to Ravenwoods's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXReplace the cap too.- Wheel Bearings
Another reason to keep my 2005 Outback- Wheel Bearings
I have a freind with a crosstek that roars. He called the dealership and they said "It's probably wheel bearings we see a lot of them". Hes got only 57K on the car. Doing a google search its not red flagged, but it does seem they are failing between 50-60K if they fail.- Wheel Bearings
Do all crosstreks seem to have a problem with pre-mature wheel bearing failure? s there a fix for it?- Need recommendation on headlight bulbs
nipper replied to jeryst's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo if you needed seat belts or tires you wouldn't replace them either? It's a saftey item.- Need recommendation on headlight bulbs
nipper replied to jeryst's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMine was so bad I finally ended up replacing them. Headlight adjustment may be part of your issue. But I always felt my 89 Justy had better headlights then my Outbacks- Need recommendation on headlight bulbs
nipper replied to jeryst's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI never had luck with it but thats me.- adding fuel injection to Ea71 1978 Brat
Well one of the reviews said he put it on a 1.8L toyota motor ...- adding fuel injection to Ea71 1978 Brat
Will this help?- adding fuel injection to Ea71 1978 Brat
Take all advertised HP gains with a grain of salt.Too many variables to actually justify the gains on all engines. Do you have the link so we can all peek at it? - 4 speed manual transmission is going out on my 84 GL wagaon
