Everything posted by nipper
Can somebody go over the engine burp again?
nipper replied to 1997reduxe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXVery easy. Remove over flow clean it, reinstall it and fill to full line. Remove cap. Start car. SLOWLY add coolant Stop when full, wait for the t-sta to opne. (you will see a surge out the filler neck) Resume slowly filling system. Replace cap. Drive car around block. Allow car to cool off. Check coolant level Repeat (once if needed) and that should do it. This is the proper method for all cars.
Starter wont engage
Bad battery cable is another possability
Starter wont engage
Except he said he is hearing a solenoid click when he turns the key. At least thats what i thought he said
Starter wont engage
have the original one?
Starter wont engage
Exactly how are these passing testing, what are those tests.
Starter wont engage
Have you tried hitting the starter? What is the voltage reading at the solenoid wire (disconnected of course). I am wondering if you have a tired iggy switch assuming the starters are not stuck somehow.
Starter wont engage
Try Neutral (amuse me). To me this sounds like a bad starter....or... You did the jump test, now try clamping a jumper to the engine block and the other side to the negative terminal
Starter wont engage
Does the starter motor spin and the engine not turn over or does it just sit there and look at you funny?
Bled the brakes three times... still no pressure.
Suggestion, the car is old enough anyway, think about replacing the MC. Also i gravity bled both my justy and outback. I didnt need anything really aside from a hose. I just opened up the bleeder and let our evil overlord Physics take over. Went faster then I thought it would, and on both cars i Replaced calipers.
What he said, thats my vote.
Paint Recomendations
nipper replied to sefferonie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXer, um, what process will you be using?
01 Outback,3.0,wont start
nipper replied to wrongturninwv's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX*makes mental note*
nipper replied to wrongturninwv's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat is high miles? This is an importnat thing to know. Timing chains usually fail when you shut the car off. The sudden unloading of a tired chain can cause it to jump, but lets not go there yet.
Remote starter info
nipper replied to Chip's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://techinfo.subaru.com/proxy/40342/pdf/040342-H001SFG000190268.pdf This should give you a pretty good idea. Not sure what year this is for but ...
Subaru radio wiring help?- new application
nipper replied to datsunscott's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWoo slow down before you make a very expensive mistake. i do not know what you are installing this in, but subaru uses a lighting controller, which breaks the lighting into zones. The lighting does not go to ground, but goes back to the controller. Modern cars generally use this same kind of system. You wirit wrong you kill your dash lights and have to replace a black box (which is 100.00 new in a sooby).
Trouble getting fuel in
nipper replied to Glen9010's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://opposedforces.com/parts is your freind
nipper replied to Glen9010's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat is your problem, the vent valve. Not sure if it is on the tank or under the hood. Also possible you have a clogged vent line.
bouncing speedo
Can also be a bad cable.
My '84 DL COUPE
sweet little car, i love these cars
Sneak peak new forester
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAerodynamics is the reasons for curves everywhere, i do miss some boxyness. The day the Wrangler goes curvey is the day we are all doomed to driving jelly beans.
auto trans governed???
nipper replied to soobie_newbie67's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOne word, well one word with four parts... TIRES i do not know what you have planned, but make sure your tires are up to the job. Get the proper speed rated tires. Always go one speed rating higher for high speed driving.
nipper replied to soobie_newbie67's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think subaru is 119 mph.
nipper replied to soobie_newbie67's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat is more limited by the ECU then the TCU. In reality it is also the physics of the driveshaft, speed rating of the wheels, and aerodynamics vs power of the engine.
Hello
Welcome to the site,
nipper replied to soobie_newbie67's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOld transmissions used to use govener/throttle pressure to make shift points, now it is all done electronically.
