Everything posted by nipper
Subaru to the rescue, this time a Dodge Ram and a trailer
http://www.autoblog.com/2012/07/27/watch-this-subaru-lug-a-ram-pickup-and-a-trailer-out-of-the-mud/ OR http://youtu.be/q3jiy2nxkCY Try that
Help please..brat will not turn off :(
Odd this is the second "my car wont shut off" post. The other was a starter that wouldnt shut off. This I would start at the iggy switch, as the actual electrical circuit is not that complicated.
Minimum pad thickness
65000 miles on brake pads, just replace them when you get a chance. That is extreemly good life on a set of pads. Better to do it now while the weather is nice then when the squeel starts in a january snow storm.
[97 Outback Sport] - Won't Shut Off w/ Key 3 Days after Installing Alternator
nipper replied to firstjump's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would pull the starter and inspect it. Hopefully the drive took all the abuse and not the flywheel.
rear brake cylinder 2002 forester
nipper replied to babyfacefitz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCouped not necassarily. With front discs and rear drums there are a few shops that will pull the rear drums (one) for inspection. not defending this shop just throwing it out there.
nipper replied to firstjump's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI keep forgetting that option as we do not have any rebuilders around here anymore.
nipper replied to firstjump's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXActually as weird as this sounds to you, it is not a complicated thing to diagnose. If you arent doing the work yourself a shop can figure it out quickly. If you are doing it yourself all you need to do is disconnect the minor lead at the starter and see when that has voltage.
nipper replied to firstjump's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJohn, it is the neutral saftey switch. It disengages in gear as it has it's power cut off.. Wait ... That would lie blame at the iggy switch. If the solenoid was shorted it would care less where the power came from.
nipper replied to firstjump's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour solenoid is stuck/shorted. Sounds like you need a starter. When you turn the key you power the solenoid. The solenoid has two purposes. The first is to push out the starter drive gear to engage the flywheel. the second is to connect the starter motor to the battery and cause the motor to spin. If you have a test light or a meter, you can test the smaller wire connected to the starter. That comes from the iggy switch. If it is powered only in the crank position it is the starter. If it is always powered iot is the iggy switch.
How To: Dimmer wire for an Aftermarket Radio Head Unit
nipper replied to Fairtax4me's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSome units are just looking for a signal, some are actually illuminating the units. The 2nd one makes the magic smoke appear. I just tapped into the lead to the glovebox myself since that light only comes on with the lights.
Temp gauge increases with AC on going up passes
nipper replied to gtparky's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck your CV boots also. I would also go for a new subaru T stat as long as you are draining the system, but it does sound like a clogged radiator. Are you the original owner?
95 legacy bogging out
nipper replied to Maleki777's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy car would bog on occasion till i changed the front O2 sensor. Give it a full tuneup also including a PCV valve.
Slipping transmission?
nipper replied to justinae's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
- 2000 Outback Wagon Ignition Cylinder and Key...impossible to find???
nipper replied to tgrey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm not sure of the issue as SMP (Standard Motor Products) has them all over ebay.- Repeat burnt valve - '96 EJ22.
nipper replied to GeneralDisorder's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat he said- rear brake cylinder 2002 forester
nipper replied to babyfacefitz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf the wheel cylinder itself and everything behind the drum is dry, I would suspect you do not need cylinders. That said, the car being a 2002 a brake fluid flushing would be in order. replace the hardware? if the shoes are wearing evenly i only would if the kit was on sale. Replace ball joints in pairs, as if one is bad the other will not be too far behind. Are you doing this work yourself or is a shop?- Trailer Hitch Question
nipper replied to JT95's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDescribe said universal hitch.- [97 Outback Sport] - Won't Shut Off w/ Key 3 Days after Installing Alternator
nipper replied to firstjump's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes the starter just spin if you were reattach everything right now? Sounds like this can either be a faulty solenoid or faulty iggy switch, but usually it is the solenoid. I think this is just coincidence.- Transmission Diagnosis help needed
nipper replied to cc.ellis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk very 1st step, flush the fluid. it can solve many issues on a AT.- Transmission Diagnosis help needed
nipper replied to cc.ellis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXlets recheck some things: Does your spedo work? Do you have an ATF temp light when the car is turned "on" Does the same light flash on startup? Do you have a check engine light on What does your fluid look and smell like?- R.I.P Roger "Tobias" Roberts
I'm sorry.- Those of you in areas that offer no coolant recycling - what do you do?
http://deq.mt.gov/Recycle/Where-to-Recycle_New.mcpx does that help?- Those of you in areas that offer no coolant recycling - what do you do?
Electrical repairs must have been fun (envinsions wiring harness in a box)- Those of you in areas that offer no coolant recycling - what do you do?
(sneaks up and touches TheLoyale's car) - 2000 Outback Wagon Ignition Cylinder and Key...impossible to find???
