25
Everything posted by nipper
Why was the car towed home?
rearview mirrors with Compass and temperature sensors
nipper replied to Stubies Subie's topic in Subaru Retrofitting
Hrmmm I just used a windshield mount and kept the plastic cover from the stock mirror to hide the mount. -
http://www.autoblog.com/2012/07/27/watch-this-subaru-lug-a-ram-pickup-and-a-trailer-out-of-the-mud/ OR http://youtu.be/q3jiy2nxkCY Try that
Help please..brat will not turn off :(
nipper replied to waldoz's topic in Historic Subaru Forum: 50's thru 70's
Odd this is the second "my car wont shut off" post. The other was a starter that wouldnt shut off. This I would start at the iggy switch, as the actual electrical circuit is not that complicated. -
65000 miles on brake pads, just replace them when you get a chance. That is extreemly good life on a set of pads. Better to do it now while the weather is nice then when the squeel starts in a january snow storm.
Your solenoid is stuck/shorted. Sounds like you need a starter. When you turn the key you power the solenoid. The solenoid has two purposes. The first is to push out the starter drive gear to engage the flywheel. the second is to connect the starter motor to the battery and cause the motor to spin. If you have a test light or a meter, you can test the smaller wire connected to the starter. That comes from the iggy switch. If it is powered only in the crank position it is the starter. If it is always powered iot is the iggy switch.
If the wheel cylinder itself and everything behind the drum is dry, I would suspect you do not need cylinders. That said, the car being a 2002 a brake fluid flushing would be in order. replace the hardware? if the shoes are wearing evenly i only would if the kit was on sale. Replace ball joints in pairs, as if one is bad the other will not be too far behind. Are you doing this work yourself or is a shop?
I'm sorry.
http://deq.mt.gov/Recycle/Where-to-Recycle_New.mcpx does that help?
