25
Everything posted by nipper
CV joints are in the two front half shafts. There are four in total that make the front driveline (2 cv per). There are four universal joints in the driveshaft that goes from the transmission to the rear differential. At the rear there are two more half shafts with 4 universal joints. These are basically trouble free.
Crank and cam position sensors only throw codes for faults while the car is running. Stalling do to a sensor failure wont throw a code as the car needs to be running. If the sensor misbehaves then it will throw one. These things are tough. Lest start with basics. Clean the battery terminals, make sure they are tight, and give the car a tuneup. That would goive us a good baseline to start.
rearview mirrors with Compass and temperature sensors
nipper replied to Stubies Subie's topic in Subaru Retrofitting
Never keep heat shrink tubing in a car parked in the sun in summer either. Make sure you grab the temp sensor too as that can be hidden in the cowl, fender, bumper or grill. -
SUbaru gauges are refernces and not bible, however they read empty early so they wont strand you, and for the most part the low fuel light means low fuel. They use two senders oner right (with the fuel pump) and one left. Usually putting in a can of texron is the first attempt to a repair. Second is to take the senders out and clean them with a #2 pencil eraser gently.
Maybe your too new to be allowed to do it. nipper.dawg@gmail.com
What's up with these ball joints? (pics)
nipper replied to l75eya's topic in Old Gen.: 80's GL/DL/XT/Loyales...
SKip Rockauto as they may not know about it (but may be able to sned you a matching one) I would call MOOG and ask -
Freom what I can see, they look differnet, but the critical areas and function are the same. I bet one is either a in house production run vs a vendor supplied part OR a production change to save costs. Or a mistake. I would call them. -
prvt me your addy, it will be between 5-10.00 (I'm guessing closer to 5.00. I have no issues with shipping first and you paying later.
hrmmm. I slept on this over night and I think there may be a simplier more elegant solution. A throttle kicker solenoid. An IACV can be blocked off on performance applications with no issues. A throttle kicker does the same thing as an IACV for your purposes but without plumbing. It just kicks the throttle open a hair to compensate for load. Many feedback carbs had this. My Justy has one.
SIlly question, was this a custom intake manifold so it just wasnt used ?
Since this is not a ton of money here, may be only one way to find out
Some background on what you want to do http://www.megamanual.com/ms2/IAC.htm not sure if that will help.
