25
Everything posted by nipper
Yes. i havent used Coopers in ages. Just the Justy needs tires and cheap ones at that. These were the first ones that came up on the list that was not some wierd chineese brand.
has anyone bought cooper tires of late. Looking at Cooper Lifeliner tires 175 70r 13 for 49.00 each.
I agree, sounds typical.
Sounds like your voltage spiked and took out the weakest links. There may be two bulbs, only one way to find out. If the bulbs are cheap enough you may think about replacing all of them (the internet is your freind). Check the fuse box and see what else operates off that same circuit. If everything else works, then it is not a main fuse or fuseable link.
Er ... no. If that was the truth we would all be having issues. CV grease is different from axle grease (generic term) and doesnt really dry out. Cage reversing is so much work IF it was a cv joint would be easier just to get a rebuilt axle. Rear cvs do such little work compared to the front, that both cages see the same wear and tear. It is not like the front (for arguments sake only as I would never ever recomend this) where the outers see more stress then the inners. Can you post the thread here to refresh our memories?
You can shop around and get good warrenties on transmissions. Don't go toa chain, due a lot of research on the net and ask around. There are great shops out there. Some rebuild them on premises, some get them from rebuilders. Also it is not so much the warrenty but where else besides the original shop can also cover it. A place that installs rebuilt transmissions will cover everything. Extended warrenties on older cars are basically a ripoff. They were sued here in NYS by the atty general. They are not worth the money.
ABS issue
nipper replied to brysawn's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Tone rings break easily when disturbed, and not uncommon to break on something as simple as this. -
Let's play the "What is this?" game!
nipper replied to l75eya's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'm sorry, i can't beyond the question due to how SHINEy everything is. -
I would run two new grounds, one from the tranny to the engine (or anywhere else) and the other from the engine to the neg battery pole. You can do just a drain and fill 4x and that would be a good flush. Don't use synthetic, i agree. The CEL would be interesting. At your milegae the dreaded O2 sensor would be, well, just a bad O2 sensor, which may be the issue (but a long shot). If it is a bad lockup, driving in D3 it should go away. If it doesnt it is not the TC. D3 inactivates lockup.
The littel amplifier in the disty that goes bad can drive you nuts. Sometimes it works sometimes it doesnt.
