25
Everything posted by nipper
code 13 is shift solenoid 3. It may be sticking or dying. When you manually shift you are operating the valves in the transmission via a linkage over riding the electrics. Sounds like you just need a solenoid (hopefully) as it is failing electrically somehow. http://www.ultimatesubaru.org/forum/showthread.php?t=33331 scroll down to the pdf file.
I have a mental block against OBD1 carbs
nipper posted a topic in Old Gen.: 80's GL/DL/XT/Loyales...
Good news - Justy has a working exhuast system Better news - valves all adjusted runs quiet Best news - IT RUNS not so good news. Has a very loopey idle. Easily stalls. Prefered Idle speed someplace between 1200-2000 rpm. There is a random miss at all rpms. Trust me this is a huge improvement over what it was. I think pouring gas straight down the manifold was more effecient then the old carb. Justys really do not have complicated emissions systems, the carb has a duty solenoid. All new ignition parts. The miss is driving me a little nuts as iggy timing doesnt doesnt affect the miss (does effect the engine rpm so that is ruled out). Car will run smoothly for the first 10 seconds it is started. The only known carb issue is that the evap vent valve in the carb really doesnt exist. The rubber seat on the piston is 1/2 gone. I havent ruled this out yet as the issue. I am thinking duty solenoid due to what happens at the cold start. Car does fire up every time easily it doesnt labor or putput like it is flooding. This carb came off a perfectly good running justy. The previous carb was rebuilt and royally ruined by a rebuilder. Oddly I am not the first justy person to have this issue. 30,000 original miles, engine is tight. I don't think it has anything to do with the car sitting for many years, but I am open to reasons. I do GREAT with the nightmare 1970's and 1980's emissions and carbs, kick but with Fuel Injection. This is my black hole of induction. -
Does your engine oil change like gas? Put the snorkus back on untill we figure this out, too many changed variables can make it impossible to diagnose sometimes. I get 18 around town with a stop sign on every corner, 24-25 above 70, below 70 27-28. A none OE air folter can screw up the intake sensor. Check for dragging brakes. The high flow stuff is a bit of a waste on a subaru unless you put in cams.
You do all that work to skimp? Never replace a timing belt and skip everything else. it WILL fail, not if at some time between belt changes. Don't forget all the seals. Why not change the front end parts. If she is keeping the car for a while she will need to replace them at some time, why not just do it and she will never have to? 180,000 they may feel tight now, but no one can tell in another 10K.
Every single transmission shop can pull the pan on any car and find brass and tell you you need a tranny. They are evil places. Pressure gauges with a test drive unless something obvious would be part of a reputable tranny shop diagnoses or at least a test drive. Get the car out of there, and what exactly were your symptons.
Hydraulic Rear e-Brake on my BumbleBeast!
nipper replied to Loyale 2.7 Turbo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The dream of many a passenger, to have their own brake pedal -
Those foot operated brakes were horrible, and there is not enough room under the dash or braces for the assembly. Ideally you want to keep E/P brake cables as short as possible, as that reduces stretch. You can either destroy your dash or your console. If it was me I would go with the VW set up.
