25
Everything posted by nipper
Dealership is best bet and the cheapest. They will make you a new set.
14.7V at idle!
nipper replied to edrach's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Mid 13, 13.9 max, yoiu have an overcharge condition, which can shorten the life of lightbulbs and electrics. It may not mean anything but check the batter terminals make sure they are clean. -
I'm going to lurk as Blu looks the same, like he had been through a flood when it was just a deep puddle.
I am proud to say that is beyond my skill level
Though they did take a pathfinder which is about the same at 7.3 inches, the 2010 8.7
Found this, not sure if we have the ground clearance Someone did hermit pass in a 2010
Do a wet and dry compression test in the good cylinders and see the engine health, it may be fine. Generally you have the valves and the rings that seal the combustion chamber. On high mileage engines, if you do a valve job, you are increasing the seal of the engine, so worn but happy piston rings may get annoyed and result in some blowby. Subaru engines can go either way on this. Luckily subaru cylinder walls really don't wear (assuming no heavy piston slap which H6 is not known for) it should be good to go. Even if it does get blowby it usually isnt heavy. The oil level will have to be checked regularly during the oil change interval (bring it down to 1000 miles the first one then do it at 500 miles from then on. There may be some alumunum bits in there and you want to get them out. Do change the oil now.
It is the least loved yet cheapest and one of the more informative diagbnostic tools there is, long before puter or engine analyzers.
ah ok, i was going to say if it jumped at idle, no damage, at speed, lots of damage. Havent seeen a guide that bad yet, your the first. I know subaru had a TSB about guides, may be that year, dont remeber. They are supposed to last the life of the car, IMHO i'm betting 200K. Good for you that your getting paid for it.
Lookie!
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
My freind just sold one. We also have a pinto wagon running around here some place. -
Lookie!
Well once the 30 active members and 100's of lurkers get a hold of it, then there is the outback board, and the offroad board.... -
Lookie!
i have all mine, lets see who crashes the server -
Lookie!
All fixed -
Bored? Can somebody explain how this all works?
nipper replied to l75eya's topic in Old Gen.: 80's GL/DL/XT/Loyales...
lash adjuster is a fancy way of saying hydraulic lifter.It is actually the pivot point for the rocker arm. the 'lash adjuster' keeps the gap in spec. does that help?
