7
golucky66 last won the day on February 14 2018
golucky66 had the most liked content!
About golucky66
- Birthday 09/29/1995
Gender
Male
Location
Barkhamsted Connecticut
Occupation
Automotive Technician
Vehicles
2004 Subaru Baja Turbo MT, 1985 Subaru Brat
Recent Profile Visitors
1395 profile views
golucky66's Achievements
Subaru Nut (7/11)
121
Yes, air in the cooling system. The heater core is typically the highest point or very closely to it (stupidly enough) on most subarus, and therefore any air in the system collects in the heater core. In my experience, typically a lack of heat only on the passenger size indicates a restricted core, but an air pocket in just the right side of the heater core could have the same symptoms. To see if there's air in the system, warm the car up. Once it's warm, while stopped in park, floor the gas pedal so the RPMs rapidly go up to about 3.5k or so. Then let it come back to an idle. Repeat until heat improves. This will indicate there's air in the system. To tell if it's a restricted core, just hold the RPMs up to like 3.5k steady in park. See if heat returns on the passenger side.
It's only single zone climate correct? Meaning, the driver and passenger cannot have different temperature settings? If so, it can't be a actuator as you have heat on the drivers side, just not on the passenger side. The actuator is working if you have heat on the drivers side. 2 possible issues. There is air in the heater core, or the heater core is restricted.
2012 Outback should have an FB engine, which is a timing chain. If it is a FB engine it does have the oil consumption "issue" that has a extended warranty. IMO. If it does consume oil, just get in the habit of checking it. And I believe on that vehicle it even has a low engine oil light. When it comes on, top off the oil. Very reliable engine besides the consumption.
More SVX
golucky66 replied to briankk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Where did you hear about the rerun of OEM struts? Any link? Just curious. -
I've seen a few Ac compressors around the 2010 age that fail. Either making noise and eventually blow up, or the clutch let's go. I wouldn't be too surprised it it just locked up. Imo, get it fixed by a professional. Doing A.C work the right way isn't for non professionals. Too much or too little oil will cause the new compressor to blow.
On off roaring with any of the new CVTs, the ECM basically cuts power to the wheels for some stupid reason. You can try turning off traction control, but that only helps so much. It's unlikely it's an engine lack of power issue, and more of the computer not letting it be under full load.
If you only run the external cooler and not through the radiator it will take the transmission significantly longer to warm up especially on the cold days here in CT. These transmissions don't typically have an issue were they fail due to them being overheated (excluding the SVXs lol) so running an external cooler doesn't really do much but hurt fuel economy due to the increase in warm up time. The transmission fluid going through the radiator actually helps warm up the transmission with the heat transfer from coolant.
