7
Everything posted by golucky66
Yeah, I'd definitely make a post looking for a Subaru mechanic in your area. That would be my best choice, just find a used tranny and have the shop out in the used one instead of messing with the front diff, ESPECIALLY if the shop doing the repair isn't similar with subarus. Unless they're similar with subarus they should not be opening up the front diff. Could you try to explain the noise it is making a little better or differently? Or maybe get a video while it's happening so people on the forums can listen to the sound to better help diagnose your issue?
- 7 replies
- center differential noisy
- 2011 Forester
(and 1 more)
Tagged with:
I'm assuming you're talking about the front diff, as the actual center diff is part of the end of the transmission and that has no dipstick because it gets fluid from the regular transmission fluid. The front diff (for ease of explanation) is part of the transmission and in order to make any repairs to the front diff, the transmission would need to be removed and opened up. Other on this board have more experience with the front diff failing (as its common I guess...?) and could give you more insight as to the noises etc. Either way, Imo, if the transmission needs to be removed due to a bad front diff, just installed a used transmission instead of trying to repair it.
- 7 replies
- 2011 Forester
(and 1 more)
Tagged with:
My brat's been stolen, heart is broken
golucky66 replied to mwhelchel92831's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That's awesome! So glad they found it! Even if there are a new few dents, still better then losing it forever! -
03 legacy
golucky66 replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I had it happen on a Chevy once and just thought it was specific to Chevy or maybe domestic. But then my buddy who has a 03 wrx said he occasionally gets a flashing check engine light, and when I pull the codes, there are none (same drive cycle and with SSM) So I'm not missing any, there aren't any. At least according to the factory scan tool. -
03 legacy
I've had a flashing check engine light with no misfire code before. I think it take a little bit to set. -
Did all brats come with rear seats?
golucky66 replied to Downwash77's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'm pretty sure there's no "holes" because they were welded in. At least that's what the nubs looks like on my 85 Brat -
2.5 swap
golucky66 replied to djmark7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
In your experience, when doing that, what do you do when there's only 1 hole for the starter? Just use one bolt to hold it in? -
2.5 swap
Some engines have 4 bolt holes and some have 8 though I'm pretty sure Still mate up and hold fine. Just an fyi -
The trailer harness for the lights. 4 pin connector. You may or may not have the harness already installed that you can just plug into.
After you do that, if you still have issues, get your hands on a scanner and check the coolant temperature that the ecm sees. On my 04 Baja, the coolant temp sensor has two different wires, one for the ecm, and one for the gauge. If the gauge goes high and the ecm's temperature remains normal, you have a wiring issue. If they both go high, then the above posters comments are true.
New water pump leaking...
golucky66 replied to BeastmodeGL89's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Unless it specifically tells you to, you shouldn't use rtv in conjunction with a gasket. In my experience, all the guys that I've seen do that, that component comes back leaking and I end up having to fix it the right way. If you are worried about the gasket being very thin or low quality, go buy a nice gasket off. Rock auto. I mean hey, at this point it needs to be replaced anyways.- 10 replies
