7
Everything posted by golucky66
See, and I've used slide hammers on the hubs before. And not once have I gotten them out that way. I'm not a 250 lb body builder, so maybe strength plays a role. But I've hurt my arm from using the slide hammer for 15 minutes trying to get it unstuck. And it didn't move the 3 or 4 different times I've tried it.
You have two options (from my experience) Get the bolts that hold the hub into the spindle and thread them in about 6 turns or so (leaving a little gap between the head and the spindle) Put a socket on an extension, and wail on the extension. Using the bolts as a way to force the hub out from the back. Alternating 2 bolts. Number 2. Causing damage to the backing plate and spindle. But will always get the hub out. Once out you can clean up the plate and or spindle. Take an air hammer (or regular chisel and hammer) and get the chisel between the hub and the spindle (the backing plate probably will be in the of fire) and chisel the hub out. Alternating location.
I'm pretty sure you can grab most manual transmission from the 90s and maybe a few from the 00s. You need the matching rear diff, and possibly the axles. Drive shaft flywheel clutch etc (or get new) As for wiring, they're all the same. Reverse lights, and if you want the neutral safety to work correctly. You'll have to wire in a relay for the starter (at least that's what I ended up doing)
Replacement High beam bulbs, LED's. Any suggestions
golucky66 replied to Walt294's topic in Crosstrek "XV"
Agreed with Carfreak here. I (stupidly) installed a set of LED conversion headlights in my 04' Baja. And while the looked super bright up close and near distance. Night vision was horrible. And I spent 110$ of a set of bulbs. So not cheap. The LED or HID retrofit is your only real option to drastically improve vision without adding more lights. -
First off. All that white stuff is from the Subaru OEM coolant conditioner. I found this out the hard way on an 09 Subaru Outback that the shop I'm with was adding to the engine after coolant flushes (thinking it was supposed to go in that new of a car) and when I had to pull the heads to do the HGs, all that white build up was in there. Being as we were the only shop that ever touched this 1 owner car. It pointed to the coolant conditioner. As for removal. Honestly, I didn't have a good way to get it out of the block. I ended up getting in with a chisel and slowly got it all out. Taking the cross-over pipe off to allow for flushing of the coolant passages with water. I tried brake cleaner, a few different forms of soap, and a few other products. Nothing took it off (at least not in a timely manner) You might be best off just getting as much off as you can, replacing the water pump. And then dealing with the a restricted radiator or heater core when the time comes. There's not many small passages for coolant, besides the lines to the throttle body. IMO, you'll be fine with just getting as much off the block as possible. I didn't do anything about the head ports on the engine I was dealing with, besides the easily accessable spots.
The memory of all keys not present at the time of initializing are deleted. So only the keys present when programming them to the car are then allowed. All old keys become dead at that point. So if you're having an issue programming and the car still not accepting then. You should probably try the dealer.
- 12 replies
- 2011 subaru legacy
- lost keys
(and 1 more)
Tagged with:
Ok, so just the solenoids require the removal of the mesh screen. Not the turbo feed. I guess I just bought the new feed banjo from subaru and didn't even think to look for the screen.
- 60 replies
- Forester XT
- VVT
(and 2 more)
Tagged with:
I have never heard of that issue before. And I have taken a turbo off My 04 Baja, and rebuilt it including removing and tightening that nut. And had no issues 10k miles later. Though there is a TSB about removing the screens in all the banjo bolts. Both AVLS solenoids, as well as the turbo one (I think) Though even if they were restricted, hard to make a connection between lack of oil and the nut coming loose. That doesn't make sense. Imo, sounds like the rebuilder screwed up twice.
- 60 replies
- Forester XT
- VVT
(and 2 more)
Tagged with:
In that area there's only 3 possible locations of leaks. Oil fill o ring. AVLS solenoid And the AVLS oil pressure switch. And the pressure switch is the most common. But as LT1 said. Be careful not to over tighten it. It's a pipe thread that's tapered and can easily crack the casting if really over tightened.
The leak could be from the oil pressure switch. Though your talking about the side with the oil fill. It's possible someone spilt oil while filling the engine. Id wash the whole area off with degreaser and then hit it with water (on a not freezing day) Then monitor that area closly for the leak. The oil pressure switch your taking about is the oil pressure switch for the AVLS so the ECM knows the solenoid moved and the cam profiles changed. The switch is just a pipe thread. So you can try tightening it a little, or putting tape on it if that's the leak.
Some people don't like used parts. You never know. And labor rate changes depending on location. The rate at the shop I'm at is 115 an hour. And a brand new oem pulley is probably at least 250. So, while I completely understand the amount you charged, you also don't work for a dealer. You have you're own business with people who trust you. Some people just want to go to the dealer and not care (as much) about the cost
"Aisin TKF-007 Engine Timing Belt Kit with New Water Pump" https://www.amazon.com/Aisin-TKF-007-Engine-Timing-Water/dp/B00HFKEL2Q/ref=au_as_r?_encoding=UTF8&Make=Subaru%7C13&Model=Outback%7C66&Year=2008%7C2008&ie=UTF8&n=15684181&newVehicle=1&s=automotive&vehicleId=4&vehicleType=automotive Added a 08 Outback to my garage (Base model 2.5) and it says its compatible.
That year is pretty good. No real engine issues, some people report transmission issues, but if you do a transmission flush or service on it when you get it, you'll be fine. These newer Subaru's, especially the outbacks. Seem to be more reliable then most if not all of their predecessors. Sparks plugs are due for maintenance at 60k FYI.
2011 Forester recall game.
golucky66 replied to greatauk's topic in Meet n' Greet. Your USMB Welcome Center
Yeah, because in the TSB they have to make sure there are "no leaks" So just clean it up, and bring it back, or to another dealership. -
What I did on my girlfriends 13 outback. It also had a leak (it was from the valve cover) But I KNEW the leak was not contributing to the oil loss. She was going through 2 qts if oil in a 5000 mile oil change. I put it on a lift (or you can do it on the ground if necessary) and cleaned the effected area with degreaser. Make it look nice and clean. So when you bring it to the dealership for the test, they don't see any leak. Because you just cleaned it. Then just make sure you clean it a second time before you go back for the end of the test. And if they ask why it's so clean etc. Just say you had it fixed at a different shop and it's still consuming oil. Because if the car fails the test. And you get a new engine. They reseal that surface anyways. So heck with paying for something I'll be free.
