7
Everything posted by golucky66
Vdc would likely come on as traction control comes on whenever the mil is set.
- 5 replies
- Valve work
- Check engine light
(and 2 more)
Tagged with:
Front caliper banjo washers
golucky66 replied to somick's topic in Old Gen.: 80's GL/DL/XT/Loyales...
See. The funny thing for me is that in most of my experience with removing brake hoses and or replacing the caliper is that 95% of the time the new copper washers leak, no matter how tight i make it. I've reused the old ones dozens of times after failed attempts with new washers. That's just my experience. I know you're supposed to replace them. But reusing the old ones are better then them leaking.- 8 replies
- brake
- banjo bolt
(and 1 more)
Tagged with:
So if i could bring up a question here. A lot of other Japanese car manufacturer use 5w20 in most of their cars for a long time. And now most of them switched to 0w20 for obvious reason. But if they have successfully used 5w20 on their engine and most of them make it 200k+. Are we talking there's an issue with subarus design that doesn't allow them to use thinner oils without compromising longevity. Because the only real difference from 5w20 and 0w20 (assuming brand and quality of oil is the same) is the cold viscosity... And while i realize cold starting and running until the engine reaches operating temperature is tough on the lubrication system etc. Does the issue truly lie with the oil. Or subarus design not truly factoring in the 0w20 & longevity.
Screen display freezes: unable to use phone and nav functions
golucky66 replied to Mabthib's topic in Crosstrek "XV"
My moms 2017 crosstrek is going in soon to have the radio replaced due to similar issues, and loss of functionality. So i wouldn't be too surprised if it was the head unit again... There's a lot of technology in those radios and if anything hangs it can cause the whole unit to crash until a reboot. -
In terms of when the car is under warranty 3/36, i wouldn't run anything but 0w20 because if something happend to the engine, they'd try to blame it on the wrong oil viscounty and your probably be out a couple grand. After that. Use whatever the heck you want. And if the tolerances are truly the same, like the manual says. Then i feel its 95% to do with fuel economy. Either way. High quality oil has more impact on your engine the the weight.
Snap on makes a very similar ratchet same angled bend etc. Not sure if the handle would swap, but i know snap on makes a very similar one if you went to buy a new one.
FB is the engine code for the newer engines. Previously it was EJ. Foresters got the FB engine in 11' in the US Outback in 12 And not sure about when the imprezas got them as they have a smaller engine. Early gen FB engines had high oil consumption issues. Unless addressed by the dealer under warranty.
Oil filter (napa gold 7712 vs 7055)
golucky66 replied to tmaloney90's topic in Meet n' Greet. Your USMB Welcome Center
No problem. -
At my shop we use the 7712 equivalent on EJ turbo engine. the 7055 goes on all EJ non turbos. Never had an issue Got one on my 09 Forester right now. -
Imo. If you ever get a knock sensor code. Inspect the harness. And then replace the sensor and harness if the harness is damaged. Honestly. They go bad after a while. 95% if people have sucess with cheap 10$ ones. But you NEED that code to go away. That will cause the ecm to add more fuel and retard timing.
While i agree the pump isn't isn't the primary issue. It could be weak causing the delayed start to be worse then it would be. You can have pressure without the adequate volume. So sure it gets to spec, but it might be working harder then it should because it's having a hard timing filling the lines with fuel. But if while it's running you're not experiencing running concerns above 4k rpms the volume is likely fine. Almost certainly ruling out tight pump itself. At this point. It seems like there's a leak somewhere. Injector, check valve, or external leak. Just got to find it
It's in the nature of the cvt to get to high rpms rapidly and then stay at a high rev without "upshifting" because there's no gears. So it will rapidly climb to 5-6k rpms if you're heavy on the gas. And as you let your foot off the gas, the rams will slowly drop until you're easy on the gas and at cruising speed. Can the boxer engine handle this? Absolutely. Don't worry about the rpms being high when you need power.
So typically if it leaks down it isn't always an issue. It could leak down to 0 psi but provided there's still fuel in the entire system (rail included) the pressure should skip up immediately when key is turned on. What i would do is leave the pressure gauge hooked up over night. See what it drops down to. Then in the morning turn the key on and see what the gauge does. If it very slowly or not at all (right away) climbs in pressure, you might have an issue with the pump itself ir the check valve. But if you turn the key on, pressure immediately spikes to 45 psi, and it still has a long crank. You can probably rule out fuel as an issue.
