Aluxes
Everything posted by Aluxes
Well finally got to the bottom of the problem with no hi-beams. After going through everything with a volt meter, turns out that the Painless Performance harness had a bad connection inside one of the relay plugs. Had to pull it apart, but when I did it was no attached and the wire was clamped down so tight that is just cut right right through it. Im gonna call them back tomorrow!
Ok so got the Painless Performance harness installed on the 97 OBS. Not so painless after all!! First the harness plug wouldnt connect into my headlight pug. Had to cut the top half off to make it fit. Second i couldnt unplug the headlight connectors after connecting to the bulbs. IDK what the hell kind of super plug Painless uses but once you put it on good luck taking it back off!! Ripped the back completely off one bulb trying to unplug it. Chewed up both new plugs pretty good trying to pry them off with a screwdriver. Third!!!! When I did the first test both hi and low beams worked. Cut the power and ground to length and reconnected but now only low beams. Maybe the relay? IDK. The lows are brighter than before, but that doesnt really help without hi beams. Any ideas out there?
I dont think that would make a difference on my glass lens, lol! This is the second plug that has melted within 8 months or so. Anyways thanks for the reply's, but I found a Painless Performance upgrade that should work. The headlight plug doesnt fit but I can just cut it and wire it in. This is supposed to increase the voltage to the bulbs and brighten them up a bit, or I can at least run higher wattage bulbs.
I just want to upgrade the wiring to the headlights because they are dim and the passenger side plug keeps melting. A friend told me there was a harness upgrade write-up on a forum, but I have not found it. Apparently Painless performance makes, or made a harness but I cant find it on their website.
Im replacing the old worn stock struts, 97 Imp OBS, with BC coilovers. Im wondering what else, suspension wise I should change while in there? Ive already upgraded to 22mm swaybars and whitline endlinks so those bushings are good. Just not much of a suspension guy, so need a little advice. I think, a while back, Subaru dealer may have told me I needed to replace tie rods, or maybe it was ball joint. Dont remember though.
Im cool with that. I dont really do off roading in my OBS. Just some dirt roads into my property where a bit more clearance is nice. As for on road, I do a lot of freeway miles to gigs and such. I love my 22mm sway bars so stiffer springs will just add to my joy of driving. Just hope my new tires fit in the wells! Thanks for the info!
It wouldn't perform well off road, or on road?
Just curious, has anyone tried a set-up with coilovers and taller tires instead of struts? Coilovers have a smaller diameter spring and no spring perch. For example I have a 97 Imp OBS. If I installed coilovers, could I run taller tires than 205/60/15, which is what I have now. Im thinking 205/70/15 for winter tires and 215/55/17 for the summer. IDK just a different thought on the ability to run taller tires.
