Gender
Not Telling
Location
Nelson BC
Referral
Google
Vehicles
1992 Loyale, 1993 Loyale, 1994 Loyale
jetpilotdc10's Achievements
Advanced Member (3/11)
3
Sorry, sometimes I forget to mention things that I think are obvious (or assumed to be done) such as the fact that it's been soaking with PB Blaster for 24 hrs, and that I'm using a sledge hammer. I tried threading longer bolts in from the rear, but without a hoist there's little room in there to hammer them. The hub seems to have moved about .5 mm, but doesn't seem to want to go any further.
Thanks everyone! I figured it was the left one, but I have been wrong in the past about which side was the culprit when I had a rear bearing go on my Loyale. There's certainly no play in any of the wheels when rocking the 12 & 6 o'clock positions. And yes, '08 has HBA's. Hardest part will likely be rusty bolts. I had a rotor off the other day and that was a serious challenge that required some creative thinking and a lot of patience.
While driving I can hear a hum coming from the front end. Certainly sounds like a wheel bearing to me, but when I raise the front end and spin the wheels, they are smooth and quiet. The noise get louder with speed. When I turn right the hum turns to more of a growl. When I turn left, it almost goes away. These bearings aren't cheap, so I would appreciate anyone's experience on this so that I don't replace the wrong bearing.
EA82 rough accerlation
jetpilotdc10 replied to jetpilotdc10's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I really appreciate your vote of confidence and all your help. I'm taking a mental health break and will resume work in a day or two. -
Regroup, great idea! I just spoke with the previous owner. He doesn't recall having a CEL (so no code 55) the last time he drove it, 2 years ago. He's not sure if the car is originally from Cali, but he's pretty sure its not the original motor. Fuel pressure is a steady 23-ish psi at all throttle settings. I have yet to test it under load. Fuel pressure regulator, pump and filter have been swapped with no change in performance of the fuel system. I noticed a broken wire on the sending unit, but the fuel gauge still works. Timing has been double checked @ 20 btdc with green connector connected. Also swapped distributor & coil, and replaced cap, rotor, wires and plugs. No change. When I got the car, the #2 camshaft was 180 backwards. I reset the belts very carefully and they appeared to be fairly new. I have yet to plug the EGR, but I did test it with vacuum and it stalled....pretty sure that's a pass. PCV was cleaned and provided 19hg of suction at idle. Vacuum was steady at 19hg at all throttle settings. I've cleaned and/or repaired all grounds under the hood that I could find.....drivers side valve cover, t-stat housing, and the big one near the starter. I applied a very thin coating of dielectric grease to all ground terminals. I think I'll start today with an ECU swap, followed by fuel pressure test under load and a compression check. I'm about ready to give up, but it would be a shame as the car is fantastic condition! 9/10, no rust at all! -
What are the odds that my o2 sensor is bad, but not giving a code? It obviously has a direct influence on fuel mixture. This sensor looks like its been in there a while, and its the only sensor I haven't tested. Throttle, coolant, and MAF sensors have all been tested as per the FSM. -
This whole damn situation is nutty!! haha -
I'm 99% sure I'm reading it right. Maybe swap my ECU from my 92 parts car? Can that do damage in anyway? -
PCV was a little dirty but is allowing for 19hg of vacuum. I've inspected every vacuum hose and they look good, but I suppose could connect a vacuum gauge to each one and see if there's a difference anywhere. -
Do you think this could be related in any way to my code 55?
