4
Everything posted by the sucker king
I don't know what you're talking about. prick.
Jon, I don't think $100 is unreasonable. We'll work something out. I'll take it up through PM. Thanks, John
I looked and didn't see anything on ebay. can you send me a link or why not just say how much this dude wants? I pm'd him but got no response.
whatever happened to this? did moosens get his greasy little new jersey fingers on it? what's that? he's from southern connecticut? Same thing! OH SNAP! DAMN! No you diddant! anyways, I NEED a rear bumper for a 77 stage 2 wagon? anyone? (don't care if it's stock, any gen one wagon bumper will do.) I have a SWEET front bumper to trade!
the square holes are for the bumper mounting brackets, there is a chrome round headed bolt with a square underside that keeps it from turning while you tighten it down. the oval slots are for the black rubber bumper end thingies. It looks a lot like the one i pulled off my wagon, i'll try to get some measurements tomorrow. how much you want for it?
68k RX coupe in Denver junkyard
the sucker king posted a topic in Old Gen.: 80's GL/DL/XT/Loyales...
at CAP on Radcliff there is a white RX coupe only 68K miles! It just hit the yard late last week, and it's already picked over pretty good. I took the rear diff yesterday and on saturday a guy took the interior and the tranny. Still left is good dash, air dams (rear wing is removed but inside the car), good doors and front and rear bumpers in gray and white. also lenses. go get some stuff! -
also, I would think it is a rear bumper, the box said R bumper, and the front bumpers usualy had a flat spot for the liscense plate to sit. I have my damaged gen 1 stage 2 bumper from a 77 wagon that I can take pics and compare, but I'll need some daylight to retrieve it.
hey, if that turns out to be a gen 1 rear bumper, PLEASE let me have a crack at it. I need one oh so bad! John
New gasket and windscreen!!!
the sucker king replied to Leeroy's topic in Historic Subaru Forum: 50's thru 70's
Your alive! -
do the chrome strips hold the goods in place or are they just decorative? -
Belt Driven Fan?
the sucker king replied to the sucker king's topic in Historic Subaru Forum: 50's thru 70's
What was the point of the fan? My car runs nice and cool, in fact I don't even know if my electric fan works, I don't think it has ever gotten hot enough to kick on. -
what's up with the gen 1 engine (belt) driven fan? My '77 manual says they were on 4WD only. What was the point of this? I ask because mine seized up, and I figure the easiest quick fix would be a smaller belt that by-passes it. but while we are at it, does anybody have the dimensions or part #s for the bearings (I think there are 2) for the fan?
Historic Ice Racing On Lake George!
the sucker king replied to Mike Kamm's topic in Historic Subaru Forum: 50's thru 70's
Awsome pics man! I gotta get up there some time. Lake George was my first home, born in Glenn's Falls in 1969 when my parents lived and worked at "top of the World" resort in L.G. I was last up there around 1998 visiting with sis and mom. This event looks like a good reason to drive across the country! yaeh, talkin ************ i know! Dare me, moosens! -
1977 1600 wagon found
the sucker king replied to coylethebarbarian's topic in Historic Subaru Forum: 50's thru 70's
Hi I could use a bunch of things off the car. Rear bumper, gas filler door, rear and side lenses, just to name a few. interior color? -
Play in tranny main shaft
the sucker king replied to the sucker king's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'm talking about replacing the transmission, not the shaft or the bearing. anyone else think a little play is okay? -
play side to side. wouldn't be a pain, car is under the knife, engine is out and now is the time to replace the tranny if need be. I would be interested if anyone out there has a tranny not in a car maybe you could see how tight the main shaft is for me. -
Should there be any play at all in the tranny main shaft? This is an ea81 4wd 4spd. I can wiggle it just a little. You can see it move, not just feel it. I thought it should be way tight. what say you? It was not making any noise while driving.
weber vacuum hookups on 77 ea71
kay thanks, that about covers it. cept one more thing. the fuel-in line on a weber. you can run your fuel line in from the back or front? that sort of y shaped intake fitting is just a matter of where it is more convenient to run your fuel line? cause mine is on the front and i would rather run it into the back. -
hey thanks for the response. i can't look right now to say if there is the egr port on the weber. what if there is not? what should i do with that egr line? and what about the canaster stuff? -
since this board never gets tired of weber swap questions.... 1977 ea71, got the weber put on and would like to get all this vacuum stuff squared away. the car has a vacuum modulator seen in this pic: the modulator is right in front of the carb seat with four ports on the top (there is still a hose on the fourth port in this pic) and three ports on the passenger side. it's purpose is to simplify the hoses and while it does that, it also makes it harder to trace the vacuum system. i do have a diagram from the apropriate fsm, but it can't be trusted 100% because the modulator is different for MT, AT, high altitude, 4WD, etc... it does seem to jive for the most part, though. let's refer to the ports on the top of the modulator as 1 through 4, left to right AS THEY APEAR IN THE PIC. 1 through 3 went straight up to the carb in obvious fashion: my weber has one port, it's on the front near the base. i had it hooked to the disty advance on my other car. port #4 on the module doesn't worry me. it went to the side of the carb above the float bowl and it t'd off to the brake boost vac line. i capped it at the brake line. port #2 t'd off to the canister. is this the purge? do i run this into the pcv junction? the only other line between the canaster and engine goes straight into the manifold. where does the canaster collect from? what to do with the retard from the disty? what about the line from the egr that goes into the vac mod? and i have one vac port on the manifold capped where the costing bypass thing was, so i can use that if i need to. -
EA 81 A/C installation
the sucker king replied to caliplates's topic in Old Gen.: 80's GL/DL/XT/Loyales...
hey i've got all the factory paperwork for ea81 ac including installation. i could scan it later this week and maybe this should be up in the repair manual. -
Cool GF Outside of School
the sucker king replied to mikeshoup's topic in Historic Subaru Forum: 50's thru 70's
I've seen that car twice in Lyons. It is friggin BEAUTIFUL! where did you see it? -
1984 ea71 is dying, need help 1984
the sucker king replied to rridenour's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i know for sure that the exhaust from your ea71 will not bolt up to an ea81. i would say the same for the intake manefold, but i don't have first hand experience to say 100%.
