4
Everything posted by the sucker king
how do you remove the door/body bumper strips on ea81 style cars? i'm not talking about the wide black ones near the bottom, but the chrome and rubber ones that run right through the middle of the door and body. the rubber strip peels right of, but the chrome thingy is rivited on. so how do you remove without damaging the body?
one thing is your car might backfire with more unburnt mixture making it to the exhaust. but i don't think there is any emissions device that will make your car run bad if without.
i have it! send me an email adress and i'll send a copy to you hello rusty jones......goodbye rusty cars!
EA81 DL >>> GL dash swap?
the sucker king replied to baccaruda's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i have to do this, too. i was thinking of swapping the harness, so i'll be interested in what you run across. any time frame? also i've taken a couple dashes out and it's a pretty big pain in the rump roast, like ed says, it just takes lots o patience. i've never installed one, i would think it's harder. if your windshield needs replacing, do your dash swap with the windshield out. it will be much easier to get in place and you'll have way better angles to work with up top. -
80 hatch rear axel
the sucker king replied to fishmand's topic in Old Gen.: 80's GL/DL/XT/Loyales...
hi dave, there should be just one bearing assembly that the spindle passes through. is it possible that your bearing assembly has broken given the illusion of two bearings? or maybe i don't understand? we are talking about the spindle, bearing, drum/hub, and not realy the rear axel "halfshaft", correct? what is the book you are refering to? i could scan what the factory service manual diagram for that model if it would help. you have a 1980 hatchback, the best car EVER made. -
that's too bad, the suspension parts are easy to replace if you have a parts car or can get parts from a junkyard, if not it's certainly not worth repairing on an old rusty car.
round headlights on hatch?
the sucker king replied to monstaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
std had single rounds but not on early models like 1980. on those eary models dls had the rounds (unless they came with an 1800, then they were square. i do not know what year the switch was made. geeky or what!! -
it sounds like the radius rod (or leading rod if you call it that) got badly bent. and probobly the control arm too, if it moved far enough to pull your axel out. put the front of the car on jackstands and compare each side i bet it'll be some pretty obvious damage. good luck. are old subarus abundant in your part of the world (and just where is that)?
Rare Subaru Spotted...
the sucker king replied to XSNRG's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i saw what was probobly this same car a couple years ago at superupair in boulder. small world and we're geeks. -
kinda pointless but...
the sucker king replied to scrap487's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the how to keep your subaru alive book is awesome. your gonna love it i guarantee it. yes everyone should have a factory service manual, but i tell you the how to keep book is worth it for the drawings alone. nice scores. keep the chiltons book in the back of your car at all times. the pages are nice and thin and if you ever need to take a dump in the woods it makes decent t.p. -
converting FWD to 4WD??
the sucker king replied to 75subie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
that is what i was told, but i wouldn't know first hand as my car was an automatic. you can make it fit, though -
after re-reading you post i realize that this all depends what your "rusty ea71 4wd" is. are you talking about a gen1 body? cause if you are the suspension parts and gas tank won't swap in a straight up bolt on mannor. i had assumed you were talking about mutating 2 different gen2 cars. if not, forget about my advice, it won't fly. -
yes on gen 3 cars the gas tanks for 4wd and 2wd were the same, but the car in question is an 81 and i am absolutely certain the tanks are different. i was told the minimum you would have to lift your gen2 car to get the diff not to rub on a 2wd tank is 4 inches. the 2wd tanks on gen2 cars hold 13.2 gallons as opposed to 11.9 gallons in 4wd tanks. there is a VERY noticable difference in the tanks just by lookin at them. -
i was in your exact situation. i had a rusty 4wd '80 hatch with a 1600 and single range. i bought a 2wd '80 hatch with a 1800 auto and near perfect body. i wouldn't call it difficult, but time consuming and at times patience trying. go slowly, i converted mine over the coarse of a winter, so i wouldn't recomend taking your daily driver apart and trying to convert it over a weekend. come monday, you'll have to hitch to work. yes the tanks need swapping, but that's no problem at all since you will have the rear crossmember out. you don't need to swap front suspension, but the 4wd struts are adjustable, so i did. the single range tranny will end up in your backyard with snow on it. get a d/r from a junkyard. other than that, i would say the single biggest pain in the rump roast was swapping pedal clusters. there is lots of little stuff like cutting a bigger hole in the body for the stick shift, and mounting the fwd lever. also i have been told the only reason i didn't need to bang the hell out of the body to make the new trany fit was because i was using the body of an automatic car, which had a wider tunnel. if the new car had been a manual 2wd, the tunnel would be narrower and require mucho bango. hope that helps, ask me an specifics you want, i'll try to help. i feel bad for subarus who were born with power only to their front wheels. through organ donor programs like this one, some day all old subarus will walk on all fours. -
need another answer
the sucker king replied to cowboystrait's topic in Historic Subaru Forum: 50's thru 70's
the torsion bar is inside that thick tube that is the main crossmember. on a 4wd model it is adjustable with a big bolt in the center of the crossmember. you access it through a whole in the body of the car underneath the back seat. you have to lift the rear end of the car up when you do it. -
need answer
it should be just a shock absorber and a trailing arm that comes off of a tortion bar -
'70's subaru spotted
the sucker king replied to zyewdall's topic in Historic Subaru Forum: 50's thru 70's
i don't think so. -
wow. that looks just like te fe i worked on today at pull n save. but nicer. this could be worth a road trip. zyewdall i'm gonna pm ya. moose i got yer glass. -
Historic Ice Racing On Lake George!
the sucker king replied to Mike Kamm's topic in Historic Subaru Forum: 50's thru 70's
i was born in lake george in 1969. im serious. ever heard of top of the world? -
i was told that fe's had a different cam and possibly different heads than the standard ea71s. is it true? they got better mileage and were sopposed to be zippier then regular ea71s so something was different. there is one in a jy in denver, i want to pull the engine if it is truely special. anyone? bueller......bueller....... it's got some good interior stuff if anyone needs....
Denver Junkyard Run
the sucker king replied to blownbimer's topic in Meet n' Greet. Your USMB Welcome Center
so did you guys see anything cool at the yards?
