Everything posted by Ross
I also have one of those timing window plugs, fits normal ea81 too. it has "E81" and "E71t" written on it, wonder whats with the absesnce of the "A"? I had a wrecker swear to me that they had had an ea71t in there, i'm skeptical though..... Probably wouldn't be mentioned in a NZ manual, the ea81ts didn't come out new in NZ so i suspect that if the ea71t does exist it probably didn't either...
Volume Air Flow - The flappy door sensors like the ea81t and early ea82t uses measures air volume, as opposed to the late ea82t hot wire sensor which effectively measures mass flow rate.
EA81 heads ful of ... gunge
Ross replied to cubastreet's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Sorry about the delay, i have to use dial up at my new flat so i don't get on often.... I got most of my parts from Repco - if you go in there enough they'll give you a good discount, and they can get most parts. I wasn't able to get new valve springs, you may have to go custom for them....or go to subaru - their prices are good for some things, eg gaskets. Lifters were another thing i wasn't able to get anywhere other than subaru, and at nz$470 a set plus a three month wait it just wasn't worth it. I got my cam reground to factory specs for nz$70ish, kelford cams, plenty of places that do them around. Shouldn't cost any more for a different profile grind as long as you know what you want.. Crank journal grinding is tricky, because they are so narrow very few places can do them - only place i know of is Chrischurch Engine Specialists, they were very good to deal with. -
Get new bearings anyway, i got mine for like, NZ$130 ( mains and big ends) and then you know its all good. When i had my ea81t apart (bearings all slogged out, no oil pressure, black gunky crap all through the engine) the hone still looked almost new after 150,000kms, so dont judge too much on that.... But if the carbon came off pistons easily, then it probably is pretty newish. One of my pistons had small dents in it (looks like maybe the tip of a spark plug got loose) and i was told not to worry about it. -
Both ea81t and ea82t do have fuel cuts.... ea81t i think is just when the vaf signal gets too high..
Ever fix a leaky vacuum advance "pneumatic actuator"?
Ross replied to Monte's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Its not a dashpot, its a diaphragm actuator. You can get them reconditioned (ie new diaphragm) for cheap. -
LOW OIL PRESSURE and SHIFT POINT
Ross replied to JKLee's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Although if you are using an oil like 15w30, as opposed to say a 15w50, 30psi would be quite acceptable at 2500. and 15psi is heaps at idle. Pressure doesn't matter too much, since the bearings create their own pressure due to skin friction. As long as it doesn't drop below around 3 or 4 psi at idle its fine. -
WJM has seen another thing...EA82 information
Ross replied to WJM's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I've got a spare thats had a broken valve beat it up, i should cut it up..... -
EGR; replace, block, plug or leave alone?
Ross replied to dreedraffs's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The NZ didn't even get egr 'till some time in the mid to late '80s....... -
Wow, was not stranded by alternator!
Ross replied to mbrickell's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The bolt doesn't hold any torque though, the pulley is keyed on the shaft. -
ea82t reroute turbo coolant lines?
Ross replied to subiemech85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Where does the coolant supply come from on the ea82t? I know on the ea81t, it comes out of the head drain bung, need to analize the internal flow charcteristics of the head to see if thats causing any less flow around #3 or not.... Anyone keen to do a 3d model of the head, so i can do some CFD analysis on it??? IIRC, the ea82t's return goes to the thermostat housing, just like the ea81t, which is already the best place for it - straight to the radiator. I suspect that the overheating prob in that cylinder may be more to do with radiative heat transfer between the turbo and head... -
(Crazy Idea thread) What'll happen if...
Ross replied to fbh's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yeah, thats the way, shouldn't take too long if you're using a 3d package like solidworks/inventor..... Doubt you're gonna find someone with pre drawn plans tho...... You might have to get the vernier out! -
Yeah i know you can easily get the standard dual carb setup, but thats not what they are talking about. I really doubt that it would be worth modifying the standard heads to be four port - heaps of prototyping and flow bench work (unless you have access to CFD software??) would be needed to get satisfactory performance. Sub4 offers their (proven) parts so cheap it seems a waste of time to me. -
Yes, but the chance of finding those parts (twin carb setup with no crossover) in New Zealand is almost zero. -
Something to consider: It was mentioned above that the intake runners should be short as possible - its not quite that simple. If all you're worried about is high rpm performance, that is the case, but you will be sacrificing low end performance, something most ea81 drivers arn't willing to do. NZers, do a google search for Sub4, they do similar stuff as ramengines (4 port dual spark heads, dual carb manifolds, injection manifolds etc) - somewhere in the North island i think. -
Gan 2 brat - Surging/bucking problem
Ross replied to Subarutex's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'd be cheking that ignition coil. -
Another puzzle for EA81 experts
Ross replied to mortimc's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'd say its the wiper control relay going bad. When mine did it, it used to kill the ignition circuit at the same time! -
It will get much hotter than 300F. Up to around 1200F.
84 Turbo wagon failed emissions
Ross replied to blownbimer's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Check that it goes into closed loop.... once it (the o2 sensor) warms up the light on the ecs should flash quickly. -
EA82T Comp 75 120 85 120 after reseal
Ross replied to soobscript's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Why would two sets of rings fail? I could understand it if it were 1 cylinder only, or all four, but two? I notice that you didn't resurface the block deck..........could cause a prob with the HG if the previous leak had damaged the surface. (i'm not saying you should have had the block re-surfaced - that would have been much more work with having to strip the bottom end down). -
Just get the beer - the swearing will follow.
its a steel thing, botlts on on top of the water pump, using two of the wp bolts. They're easy to put on with the engine on a bench, maybe harder with it in the car.... -
Exactly!!
ea81t is nearing completion.......
Ross replied to Ross's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ahh, thanks naru. Seems to do it in both closed and open loop. Cant notice it when the high idle is going though. I'll definitely get the injectors done when i have the cash.........might be a few weeks though.
