Everything posted by Ross
EA 81 Turbo - Timing gears ever jump?
Ross replied to jamesp's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Check the timing with a timing light as said before, except on your engine the timing marks are on the front pulley. -
'82 GL....Solid or hydraulic lifters?
Ross replied to eightytwosubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
http://www.ultimatesubaru.org/forum/article.php?a=104 -
IHI VF2 RHB5 stock wastegate setting
Ross replied to TurboSPFI's topic in Old Gen.: 80's GL/DL/XT/Loyales...
or 6psig if it was on an ea81t. -
Stripped a front hub! Why?
Ross replied to Flowmastered87GL's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I use loctite spline lock when installing the hub, this prevents anything like this happening. It does mean that you need to use a puller to get it off, but IMO thats no big deal. I strongly recomend using loctite if your hub splines look the slightest bit damaged. If there is any considerable slop in the splines, no matter how tight you torque the hub nut, they will wear very quickly. -
ea71 head gasket replacement....
Ross replied to Ross's topic in Historic Subaru Forum: 50's thru 70's
Sweet ill take it out, cheers guys. -
83 Wagon and gas fill tube?
Ross replied to Urabus-84HBDR's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hello, If i remember correctly, there is a section of rubber hose attached to the filler tube just before it enters the tank. I suspect thats probably the prob. -
Its in a 79 wagon, is it ok to do with the engine in the car or should i just take it out? Cheers.
need help identifing a EA81 turbo
Ross replied to 91rss's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Should be a VF1 or VF2 if its from an ea81. -
Blown headgasket or bad turbo?
Ross replied to TomInOregon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Your turbo is water cooled. One way to check for a blown HG is to start the car with the radiator cap off. If the head gasket is blown you will probably see the cooland start to froth or bubble. Could also be an intake manifold gasket. -
Oil lamp hesitates to go off
Ross replied to Thomas DK's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Could be bad oil pump. Change the oil and filter first, see if that makes a difference. Then i'd be mesuring the pressure with a mechinical gauge, in order to asess the state of the iol pump and bearings. -
I take it then there is some relation to subgsr of Waikaia! A mate of mine may be selling his rx2 soon. I'll have a chat to him and get back to you.
I would definitely check this - something causing the knock control unit to retard the timing will give exactly the symptoms you describe.
Yeah, ditto. Never had any probs with the stock NGKs'. I would also recomend Canty engine specialists, good guys, although there really isn't any reason why you can't do most work on these engines yourself. Very easy once you get into it. Where in NZ are you from subarugsr?
Is your timing set to 15 Deg BTDC? If its too far advanced your engine could start to knock when it warms up, causing the knock control unit to retard the timing.
Did the hub look corroded at all? Also, was the thread on the end of the stub axle stripped as well? -
eeewww.. I'm with WJM, keep it below the hood.
While there is no "adjustment" provided, it can be adjusted. Its simply involves loosening the bolts where the two suspension arms meet, and pushing the assembly around with a bottle jack or the likes. I havn't done it, but an old guy i take mine to has been doing it for years, as he used to work on ea81 rally cars. He reckons its a prick to do.
LPGsuperchargedbrumby has supercharged an ea81.
Water and Oil Don't Mix
Ross replied to captainkettel's topic in Historic Subaru Forum: 50's thru 70's
What motor is this? -
Benefit: Back seat passengers don't hit their head on the roof so much.
