Everything posted by Ross
Over here is New Zealand, but SKF is a worldwide company, you should be able to find one in your neck of the woods. Some other companys use the same product numbering, im not entirely sure what ones. If you cant find an SKF outlet, just ask for a Single row deep groove abll bearing with shaft diameter 35mm, outer diameter 72mm, depth 17mm, dynamic load rating 31kN, and either one or two seals.
That part No is SKF 6207 2RS1 for seals on both sides, or 6207 RS1 for seal on one side only.
Over here they are 7206 RS2. The RS2 bit is the seals. I use RS1's - only one seal whickh i leave facing the knuckle seals. This way you can properly lubricate the bearings. Ill check on that part #, its been a while since ive bought them.
Coloured dash Illumination?
Ross replied to ausubaru92's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thats the female solution to everything isn't it? -
Quick easy t-stat question...
Ross replied to ckappler's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Sounds like the thermostat is stuffed. Many people seem to recomend oem ones, i cant say ive had a problem with others(yet). 180F should be fine. -
New(to me:) 87 Subaru GL wagon - Engine Problems
Ross replied to Rodm21's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Well, generally when you use a helicoil it involves running a special tap through the hole, and screwing in a wire insert; easy as. Im not sure how you stop the swarf ending up in the cylinder in this case though. Is there a special tool anyone? -
Latest mod.... at LEAST 50hp :)
Ross replied to TheSubaruJunkie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I think you need a Slayer one too. -
That sounds like the throwout bearing. It could also be the pilot bearing. If its the throwout bearing, the noise will not happen with the clutch engaged and the gearbox in neutral. If the noise is there, its the pilot bearing.
can an ea82 handle hydrogen power
Ross replied to dragonwingsubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Dont worry, i wasnt, i was just being a smartass. -
1983 subara gl limited edition
Ross replied to pbrsaok's topic in Old Gen.: 80's GL/DL/XT/Loyales...
insert "bu dum chhhh" on drums and corny fake laughter here....... -
Hmmm, seems odd that someone from the US is hasling a country about not conforming to the Kyoto protocol... -
Just out of interest, what makes it a limited edition? -
I agree, now if only we could make a small reactor to fit in a subie...... -
Generally, the bar just supports the struts in their original position. With the subie, you could have it pushing the struts apart, as this will reduce the funny camber they have from the factory.
Go for it! ONe other option is to split the water at home and somehow bottle it. Whether this will be cheap or not depends on your electricity prices, check it out. Dont want to be negative, but without using a catalyst of some kind, your car would be a perpetual motion machine if it worked with onboard water separation. -
Sounds like an ignition module or possibly ignition coil.
CV joint, wheel bearings or what?
Ross replied to spideyz's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If the bearings are bad enough to make a clicking sound, you will be able to feel excessive play in the wheel with it jacked up. You dont need a pres to do the bearings, just a hammer and a peice of 2x4 will do fine as long as you are careful. -
I agree that you will definately need to use stored hydrogen. To produce enough energy to beark up the water, your alternator would requre at least three times the power your engine puts out. If you can find a source of hydrogen you should be able to make it work. -
Oh... so how do you "break" the water molecules up? It requires a lot of electricity if you do it that way. -
I think it would be ok. Very little of the engines strength is required for the combustion, it is mainly to withstand the large forces required to accelerate/decelerate the pistons, and especially the con rods at high revs. I think there is only one way to find out! I'm interested to know where you plan on getting all this hydrogen, and how much it will cost? -
Maybe the water level was too low for the sensor to read?
OK, i started the engine with the green connectors unplugged. I then unplugged the coolant temp sensor. The ecs light came up, and the computer started flashsing code 33 as expected. I then turned the car off, and plugged the temp sensor back in. I then plugged the green connectors in and turned the ingnition to the on position (engine off). Code 33 did not flash, just 11 & 12 (they always flash with the ign on and engine off).
