Everything posted by BoostedBoxer421
please help with 86 RX turbo vacuumn
BoostedBoxer421 replied to angerthis's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the top sensor in pic goes to a T about 2 inches off of it. one line goes toward cab to the small vac canister behind strut tower, and the other line off of the T goes to the intake. after the throttle body.. theres a spot on intake to put vac line thats the rear passenger side intake runner about half way between injector and throttle body. the bottom sensor connects to to a T on the intake side of the turbo on the rubber boot, like i was saying with the charcoal canister hose.. mine has the 'T' metal piece in the intake boot, its pointing toward front of car when installed. the big hose on the charcoal canister thats closest to the cab of car goes to the T of that sensor if anyone with more experience in EA82T vacuum could help confirm my logic that would be greatly appreciated -
you think you mounted them wrong? or making sure you dont? you can interchange heads, i havent seen it done, but you can tell by EGR hook up spots.. and you would have to turn cam cases around i believe...? not 100% on that but hope it gives you a good idea
not always haha im at 235,000 miles and no cracks!! exhaust ports are perfect. just depends on how they were maintained
93 loyale code---weird
BoostedBoxer421 replied to bgambino's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the check plugs for the ECU are two green connectors that don't have locks, so they dont lock when plugged together.. should be right underneath ECU and not sure on the EGR, maybe someone with carbed or SPFI knowledge can chime in to help you -
Ticking coming from from axles?
BoostedBoxer421 replied to nick1208's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the inside diameter of the wheel bearing is slightly smaller than the outside diameter of the axle shaft where the bearing is pressed onto -
i had this happen with new axle and new bearings.. the axle was too big to fit bearings and actually made them bind up to the point of not turning when i tried to press the axle and bearings together.. i had to have car fixed by next day so had no choice but to hone out bearings so i could get to work. ive put over 8k miles on my 'sketchy fix' bearings and havent had and issues yet haha -
the bigger vac line thats farthest from front of car on vap cannister? mine goes to a T into the rubber intake boot on turbo.. once im out of school today i'll see where the other vac line from that T goes. im pretty sure it goes to one of those sensors/switches that you posted in pics -
EA82T - Boost but no power gain
BoostedBoxer421 replied to BoostedBoxer421's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I thought that my problem was from my coil or connections going out at first because it seemed like I wasn't getting timing advance. then my crank angle sensor went completely toast today, and now that I changed that its been running great.. if it was that causing all my problems the whole time then that crank sensor can cause some funky problems, such as my gas gauge post LOL -
EA82T dies when gas gauge moves :/
So... I have no idea why it would die every time I got gas, but my problem was from my crank angle sensor failing -
I need to find my books... haha then I can probably help you -
Now I'm kinda lost, I have my 87.5 GL with EA82T and an 87.1 RX with EA82T and they both have those same resistors or switches that Angerthis posted in pics.. aren't the pre 87.5 and post 87.5 turbo vaccum lines set up differently?? like older one doesn't use boost selenoid? when I got my RX the wastegate vac line went from wastegate straight to turbo outlet side. most the vac lines on my RX were all switched around and messed up so I thought i'd just copy my GL vacuum.. Could someone help with these vacuum switches..? Haha now im lost with my RX vacuum lines too -
I meant when you first turn key on and the pump pressurizes the lines. I noticed mine started getting louder then, and then it started running bad, but I never had a way to check fuel pressure. I have open downpipe too (: love the sound of these EA82Ts!! And never heard of that surge tank setup, I'm gonna look into that
87 gl-10 not charging
BoostedBoxer421 replied to mm88swrt's topic in Old Gen.: 80's GL/DL/XT/Loyales...
my car's had pretty bad wiring luck around there. Mine did it before because the little two prong connector going into that alt. had a bad connection, and its done that because the black fuses base burnt up underneath the box -
Is that balck fusible link in fuse box thats next to battery good? The one closest to strut tower. Or is it making a good connection on bottom of fuse box and off of alternater? -
87 gl-10 Rough Idle
+1^^ first I would think is that drivers side injectors are plugged, wiring bad, or just going out How much boost you pushin?? Injectors aftermarket? They might not be liking the higher than stock boost and are getting worn out from it -
Ea82 engine differences, carb vs mpfi
BoostedBoxer421 replied to ystrdyisgone's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Also the turbo dual ported heads have different Cams for a different valve overlap duration.. -
Yeah, the wastegate actuator vac hose goes from the wastegate to the outlet side of turbo, on the pre-87.5 I believe its just a hose about 2-3 inches long. On mine, which is an 87.5 EA82T those hoses go to a boost selenoid on passenger side strut tower first instead of just going from wastegate to turbo outlet. And I have a boost gauge set up off the intake manifold from where an old sensor was, or you can just T in at any vac line off manifold. Anywhere on the manifold after throttle body will be a good place to show boost pressure. -
Have you tried looking at a Hayne's or a Chilton's book for vac diagrams? Anything specific, or just everything vacuum related? Haha -
Front lip for '90 Loyale?
BoostedBoxer421 replied to LoyaleSmith's topic in Old Gen.: 80's GL/DL/XT/Loyales...
no, not being dumb haha ive been lookin for another good front lip too, i luckily have one good one on my RX, but i think theyre just getting rare to find -
are you running that with an EA82T block? or did you turbo a carbed block and do propane conversion? sorry about turnin the thread around, im just curious haha -
No, sorry. Im still doing the vacuum om my 87.1 RX the hard way as of about 10 min ago i have 2'' exhaust from the bottom of cat and goes to a turn down just past the back tire, seems to run smoother now, just a little less bottom end power i think. and can really hear tha little turbo spool up hella quick now it seemed to still run pretty good without any exhaust on after the cat, and the wastegate was still workin normally. with a 3'' tip on the cat I kept havin people in Chevys and big Deisels revving up at stop lights thinking i was wanting to race... lol and they thought they could beat me
