angerthis
    2
Everything posted by angerthis
  1. can any one tell me what gasket is the best for my motor i plan to take a carbed ea82 block and put my MPFI heads with turbo yes i do no that compression is higher and that is why i would like to know what is the best head gaskets to get
  2. so is there any one from Bellingham going or what?
  3. ya that would be cool if i can get the Whatcom County Subaru's on board no one has let me know so we shell see
  4. you say i have to have power to the + and - sides of coil? so put my multi-meter - to a ground and the + to coil and then do the same for the - side? i should have power
  5. calling all Subarus if you are going to the WCSS we should meet up and convoy to Pt. Townsend PM me if your in for it
  6. i am looking to set up a convoy from Bellingham you in?
  7. i know the coil and distributor are good because i pulled them out of a running car and still no spark what else can i look for
  8. so that nub that sticks out the bottom you drive it out from what way?
  9. ok if you are looking up from under the car at the shift linkage you will see what i think is a pin so you can remove the linkage from the trans how in the hell do you get that pin out i hope this is a nuff info 4 any of you if i need to i will post picks thanks 2 you all 4 help
  10. you make it sound easy i no it should be and it will be after i figure it out new 2 the turbo world
  11. ill let you know it is a little confusing but you gave a nuff info i think i can finger it out LOL i hope thanks 4 your time
  12. as long as you have not started the motor you can ree use the head gaskets
  13. my 86.1 RX has the dummy light on the instrument panel with a turbo and it would light up win i exsellerate so on your RX were does the vack lin at char-col can go to?
  14. so what is this? and do i run any vac hose from turbo 2 char-col can ?
  15. manly just 4 my turbo like waste gate vacuum line goes were? and how would i go about hooking up a boost gauge to my turbo this is my first turbo car iv had and it being a 1986.1 RX i could have not pick a more one off car if you know what i am saying LOL but true and i all ready blow my head gasket ones and would like to not do it a gen right now i am running it with out the turbo and it sucks i wont to put it back in just dont like making the same mistake a second time
  16. do any of you have vacuum diagrams for my 1986.1 Rx like turbo and evry thing els under the hood?
  17. win i got my 86 RX the motor was seized so i put the mipf heads on my good EA82 carb motor and it seems to do ok so fare
  18. do any of you have vacuum diagrams for my 1986.1 Rx like turbo and evry thing els under the hood?
  19. any one know if there is a Subaru meet some were near Bellingham wa? soon???
