Everything posted by libertyherb123
1991 Subaru Liberty Loses Power Under Load
One thing I have noticed is that the majority of the additives attempt to remove build ups from the intake valve but then get combusted in the chamber so they don't do much to the exhaust valve. Does anyone know how to gradually remove carbon build up from the exhaust valve without removing the head?
Hmm not sure? Maybe only when the issue is replicated... Under load up a hill?
Completely agree. I'll give the additives a go as I really don't want to remove the head. Thanks for your help mate. Happy New Year!
Thanks Moosens. I'm in Aus and have ordered Sea Foam and the additives described above from EBay. Any further advice would be greatly appreciated including which additives to use. Anyone else with ideas or solutions please let me know. Cheers. Ryan.
Moosens, Have you had luck with correcting this issue at all?
Great. Thanks for that. Looks like, after reading the other threads, Marvel Mystery Oil, Chevron injector cleaner and the additive you suggested might be the go. I'll also put some Sea Foam through the intake and see how it goes. Timing belt looks fine and hasn't jumped.
Ok. Thanks. How would you recommend correcting the problem? Thanks for your help.
Thanks for your help. If anyone else has any other suggesstions it would be much appreciated.
I have only tried an off the shelf product without much input from anyone else and I wasn't really sure which one to choose. Can I please ask what the products were? The Oil Additive and the Gas Additive? I am down in Australia and will see if I can get my hands on some SeaFoam.
G'Day All. I have a 1991 Subaru liberty with an EJ22 engine. It has a manual transmission. When under sustained load (accelerating up a hill) it loses power and RPM starts to decrease. If I try and accelerate through the power loss, the engine only loses more power. Changing down gears also does not help the problem. When it starts to lose power, if I pull over, the engine vibrates and feels like it is running on 3 cylinders. No codes are displayed at any time. If I let the engine idle for a few minutes, the engine recovers and performs as per normal. I have replaced the following items: MAF (cleaned) Fuel Pressure Regulator CAT Fuel Pump Fuel Filter Spark Plugs Spark Leads Oxygen Sensor Knock Sensor Coil Pack I have also run it on 98 Octane Fuel. I have run an upper engine cleaner through it and a fuel cleaner through it. It has had multiple oil changes. Does any one have any suggestions to the problem. I have done a significant amount of study and no one seems to have a comprehensive answer. Cheers.
