My original thread is right below, but I will also give a summary of the problem/fixed items. http://www.westernsubaruclub.com/smf/index.php?topic=35882.0 This is a 1998 JDM STi type R with approx 96k and EJ20K engine Problem: First time I try to start the car it will take approximately 20 cranks to start, but it will always start and never flood. ********************************************************************************************************** -If I leave the key on the "on" position for approx 15-20 seconds the car will start perfect. If I start the car, shut it off, then instantly try to restart it again it will start normal. If I start the car, shut it off, wait 5-10 seconds then it will take me 10-20 cranks to start the car. So the longer I wait between starts the more cranks it will take to start the car. -During this cranking process, after about 10 cranks the car goes into the following cycle: almost start, crank, and repeats until the car starts. If you ever got the timing belt slightly off this is what my car sounds like. -After I start the car it will surge for about 1 minute which I suspect to be a failing o2 sensor or possibly AICV (when I first got the car from Japan there was an o2 code stored which never popped up after en ECU reset) -Not sure if this is important, but there is an abnormal gurgling sound coming from the FPR/Fuel rail turbo side when I prime the fuel pump. -During regular driving and at WOT the car runs and boost perfect without any hesitation or hiccups. ******************************************************************************************************** Items I've changed: 2 cam sensors from a normally working car 1 crank sensor from a normally working car New 255 fuel pump with an assembly, I can hear the pump priming when the car is on the "on" position New fuel pressure regulator New fuel filter rebuilt starter working main relay Yes battery is fine(car cranks fast), there is fuel in the car, and no fuses/relays are blown. Swapped ECU from a working car New distributor New ignitor New fuel injectors (all 4 with all new seals) I did a fuel pressure test you can see in my first thread(link at the top) and there is a spike followed by a drop which is normal This car doesn't have a fuel check valve, instead there is a fuel return line. The only thing I haven't changed is the wires and the spark plugs which I don't suspect are the issues because the car runs perfect at WOT. I haven't checked the timing, but I'm assuming the car would show symptoms while driving which it doesn't. I will change plugs and try a different set of working wires, but other then that I'm out of ideas. I really need help
