Location
Sayre, PA
Referral
"Best Subaru Brat Forum"
Biography
Had a '78 Brat when they were new. Traded it for a '79 El Camino. Just bought another '78 (haven't even seen it yet - as of Jan 2014).
Vehicles
1978 Brat
CMJAnew's Achievements
Advanced Member (3/11)
4
Interesting! My '78 Brat's center caps look like these.....have a free spinning threaded bolt attached. They thread in, which I actually thought was odd since I've not seen others in photos.
FWI - If you're interested in the other NOS wiper motor, the one I received works perfectly.
http://www.ebay.com/itm/220828882389?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649 $56.00 including shipping. I think there is one more available.
Thanks, Bought a N.O.S. one.
Transmission Oil Question
CMJAnew replied to Seahag1978's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Would you, Could you explain the "flush" procedure. The only way I can describe my tranny fluid is RANCID. Should add, I'm in the wrong forum now (have a 78 Brat) but was looking for manual trans discussions. -
Using jumper wires directly from the battery to the wiper motor I got; tic-tic.......pause......tic-tic.......pause.......tic-tic No 'running' of the motor.
I'll try running jumpers. Do I need to be careful of Positive and Negative? If so, which terminal on the motor corresponds?
Folks, First understand I am NOT very good with a multi-meter. That is, I do a lot of touching this and that, not really knowing if I'm in the right spot(s). That said; when the key is in accessory position and/or the car is running, with wiper switch "ON" I can hear the motor "clicking" (doesn't really sound like arcing). when I touch the left (from the front) connection on the motor, the meter reads 11volts when I touch the right " " the meter reads 0 volts. Bad Motor????
Careful if you go the spray adhesive route. My instrument panel was "glued" in due to over-spray. Will be watching this thread closely for the same reason as barrett.
'78 Brat - Charging/Not Charging
CMJAnew replied to CMJAnew's topic in Historic Subaru Forum: 50's thru 70's
After getting some suggestions on a Brat/Brumby facebook page I took the instrument panel out (it was suggested a burned out "charge" light would not allow the alternator to function correctly). THERE WAS NO LIGHT AT ALL. So I switched one from the "oil" to "charge". This made no difference -- still no charge. So, I did what any normal guy would do ---- Replaced the alternator with a fresh rebuilt. NOW IT CHARGES. I was going to let it idle a while to be sure but, alas, blew the lower radiator hose. __________________________________________________________________________________________________________________ As to the instrument panel lights -- they ALL seem to be on ALL the time now. Any ideas why? And, what to do 'bout it? Plus, any ideas where to get the smaller of the lights and sockets for the instrument panel? The larger (1/2") ones are readily available on eBay. -
I bought a Service Manual -- 1600/1800 Feb 1981 reprint. MSA-111. Of course my car is a 78 Brat. Is this manual going to be an aid or a hindrance? That is, should I be on the lookout for a 78 specific manual?
Finally purchased a volt meter (extremely cheap one) to get to the bottom of the not charging issue. Tested the battery with engine NOT running = 13V (I had charged it fully a couple weeks ago) Tested the battery with engine at idling = 12V Tested the battery with engine under load = 12V to 13V Never went above 13V Do you all think I should go straight to replacing the alternator?
Do YOU know how to Gooogle?
CMJAnew replied to monstaru's topic in Meet n' Greet. Your USMB Welcome Center
Always seems to happen in the 'intro' area. -
78 Brat - Froze Up Brake Caliper
Good. Most of what was lost came from the old calipers. Very little even came from the lines.
